I faced problem receiving snmpV3 traps.I used tcpdump and I received the messages on the console, but not in the interface.
This is my snmp credentials configuration:
My rule in the Event console is listenning for everything - .* and the other filter is by IP address
After receiving the traps on the console I checked them and the configuration of the protocol and privacy pass phrase are the same.
I also enabled debug mode from the Event Console Settings but there are no enough information in /omd/sites/instance_name/var/log/mkeventd.log
About the Engine ID I placed the example from Check_Mk help documentation which is accessible from top right corner.
About the other server(snmp agent) is configured with the same authentication protocol, security name, authenthication password, privacy protocol and privacy pass phrase.
How can I check from my side which of the parameters or more than one do not match the parameters attached in the message send by the server on the other side?
Best Regards
