Ich versuche einige Lancom Router (LANCOM 1783VAW) via SNMP zu Monitoren. Das kuriose ist, bei 5 Routern funktioniert es einwandfrei, bei anderen 5 Routern leider nicht. Alle Router sind identisch konfiguriert.
Ein snmpwalk gibt mir die OID aus.
Ich bekomme folgende Fehlermeldung bei denen wo es nicht funktioniert:
OMD[xxx]:~$ time cmk -nv Lancom10
Checkmk version 2.0.0p9
FETCHING DATA
PARSE FETCHER RESULTS
Received no piggyback data
[snmp] source code string cannot contain null bytes(?), execution time 0.0 sec | execution_time=0.020 user_time=0.020 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.000
danke fΓΌr deine Antwort, tatsΓ€chlich bekomme ich mehr ausgegeben:
OMD[xxx]:~$ time cmk --debug -vvp Lancom10
Trying to acquire lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Got lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Got lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Released lock on /omd/sites/xxx/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Released lock on /omd/sites/xxx/var/check_mk/license_usage/next_run
Loading autochecks from /omd/sites/xxx/var/check_mk/autochecks/Lancom10.mk
+ FETCHING DATA
[cpu_tracking] Start [7fe979ccdf10]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath('/omd/sites/xxx/tmp/check_mk/data_source_cache/snmp/Lancom10'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
[cpu_tracking] Stop [7fe979ccdf10 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
Trying to acquire lock on /omd/sites/xxx/var/check_mk/crashes/base/ad04ab7c-1136-11ec-aba2-26ca43a40802/crash.info
Got lock on /omd/sites/xxx/var/check_mk/crashes/base/ad04ab7c-1136-11ec-aba2-26ca43a40802/crash.info
Releasing lock on /omd/sites/xxx/var/check_mk/crashes/base/ad04ab7c-1136-11ec-aba2-26ca43a40802/crash.info
Released lock on /omd/sites/xxx/var/check_mk/crashes/base/ad04ab7c-1136-11ec-aba2-26ca43a40802/crash.info
File "/omd/sites/xxx/bin/cmk", line 98, in <module>
exit_status = modes.call("--check", None, opts, args)
File "/omd/sites/xxx/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/xxx/lib/python3/cmk/base/modes/check_mk.py", line 1643, in mode_check
return checking.do_check(
File "/omd/sites/xxx/lib/python3/cmk/base/decorator.py", line 37, in wrapped_check_func
status, infotexts, long_infotexts, perfdata = check_func(hostname, *args, **kwargs)
File "/omd/sites/xxx/lib/python3/cmk/base/checking.py", line 195, in do_check
fetcher_messages = list(
File "/omd/sites/xxx/lib/python3/cmk/base/checkers/_checkers.py", line 247, in fetch_all
raw_data = source.fetch()
File "/omd/sites/xxx/lib/python3/cmk/base/checkers/_abstract.py", line 163, in fetch
return fetcher.fetch(self.mode)
File "/omd/sites/xxx/lib/python3/cmk/fetchers/_base.py", line 263, in fetch
return result.OK(self._fetch(mode))
File "/omd/sites/xxx/lib/python3/cmk/fetchers/_base.py", line 281, in _fetch
raw_data = self._fetch_from_io(mode)
File "/omd/sites/xxx/lib/python3/cmk/fetchers/snmp.py", line 323, in _fetch_from_io
persisted_sections = (self._section_store.load() if mode is Mode.CHECKING else
File "/omd/sites/xxx/lib/python3/cmk/fetchers/cache.py", line 95, in load
raw_sections_data = _store.load_object_from_file(self.path, default={})
File "/omd/sites/xxx/lib/python3/cmk/utils/store.py", line 204, in load_object_from_file
return ast.literal_eval(content)
File "/omd/sites/xxx/lib/python3.8/ast.py", line 59, in literal_eval
node_or_string = parse(node_or_string, mode='eval')
File "/omd/sites/xxx/lib/python3.8/ast.py", line 47, in parse
return compile(source, filename, mode, flags,
ValueError: source code string cannot contain null bytes
real 0m2.821s
user 0m2.441s
sys 0m0.370s
Wirklich weiter bringt mich die Ausgabe aber leider nicht.
Die Fehlermeldung βValueError: source code string cannot contain null bytesβ deutet auf ein Null-Byte in einem Python-Plugin hin. Liegt da irgendetwas komisches unterhalb von $OMD_ROOT/local?
Ich hatte schon mehrfach die fehlerhaften Hosts gelΓΆscht und neu angelegt.
Jetzt habe ich mit: find /opt/omd/sites/ | grep "Lancom10"
die betroffenen Router files gesucht und gelΓΆscht. AnschlieΓend habe ich sie neu hinzugefΓΌgt und siehe da, der SNMP Check funktioniert nu. Woohoo.
Danke fΓΌr deine Hilfe @r.sander , du hast mich erst auf die Idee gebracht
