Error:
UNKN - The discovery function “inventory_sonicwall_conns” of the check “sonicwall_conns” is expected to take a single argument (info or parsed), but it’s taking the following arguments: [‘checkname’, ‘info’]. You will have to change the arguments of the discovery function to make it compatible with this Checkmk version.
Can anyone point me in the right direction as to where I’m supposed to alter the check or check-parameters?
UNKN - The discovery function “inventory_sonicwall_mem” of the check “sonicwall_mem” is expected to take a single argument (info or parsed), but it’s taking the following arguments: [‘checkname’, ‘info’]. You will have to change the arguments of the discovery function to make it compatible with this Checkmk version.
I guess I’ll have to go through all the Inventory functions then.
Thanks so far!
This is an installed extension below $OMD_ROOT/local and not affected by CMK updates. This is also the cause of the error as the extension was likely installed when the site was running with an older CMK version.
You should check if there is a newer version of this extension available.
