CMK version: 2.0.0p23
OS version: GNU/Linux (docker)
Program '/omd/sites/cmk/share/check_mk/agents/special/agent_myspecial' not found (exit code 127)
Calling: /omd/sites/cmk/share/check_mk/agents/special/agent_myspecial '-a' '1.2.3.4.5' '-p' '20'
[cpu_tracking] Stop [7f56a1d3bd30 - Snapshot .......]
Given the error message, I double checked, and indeed my special agent is locatedlocated at the location specified where it is missing from. The file is executable (+x
) and belongs to the site user (cmk:cmk
). My guess is that since is a python code, I must do something special in order for the code to be executed as python instead of bash. However, I found no information how to do it, and in general very little information on how to build and configure my own special agent.
Special agent - Target: /omd/sites/cmk/local/share/check_mk/agents/special/agent_myspecial
#!/usr/bin/python3
import argparse
if __name__ == '__main__':
arg_parser = argparse.ArgumentParser()
required_param_group = arg_parser.add_argument_group('required arguments')
required_param_group.add_argument('-a', '--adress_ip', required=True, help="Host adress")
required_param_group.add_argument('-p', '--port', required=True, help="Port number")
args = arg_parser.parse_args()
print('<<<myspecial_response_code>>>')
print('200')
WATO - Target: /omd/sites/cmk/local/check_mk/web/plugins/wato/myspecial_register.py
#!/usr/bin/python
from cmk.gui.plugins.wato import (
IndividualOrStoredPassword,
RulespecGroup,
monitoring_macro_help,
rulespec_group_registry,
rulespec_registry,
HostRulespec,
from cmk.gui.valuespec import (Dictionary, Integer)
from cmk.gui.plugins.wato.datasource_programs import RulespecGroupDatasourcePrograms
def _valuespec_special_agent_myspecial():
return Dictionary(
title=_("My Special Agent"),
help=_("This agent is responsible for check if something response on given http port"),
elements=[
("port", Integer(title=_("HTTP port"))),
rulespec_registry.register(
HostRulespec(
group=RulespecGroupDatasourcePrograms,
name="special_agents:myspecial",
valuespec=_valuespec_special_agent_myspecial,
Argument-thingy - Target: /omd/sites/cmk/local/share/check_mk/checks/agent_myspecial
#!/usr/bin/env python3
def agent_myspecal_arguments(params, hostname, ipaddress):
args = []
args += ["-a", ipaddress]
args += ["-p", params['port']]
return args
special_agent_info['myspecial'] = agent_myspecal_arguments
Check - Target: /omd/sites/cmk/share/local/lib/check_mk/base/plugins/agent_based/myspecial_response_code
#!/usr/bin/python
from .agent_based_api.v1 import (
register, Service, Result, State
from cmk.utils import debug
from pprint import pprint
def discovery_myspecial_response_code(section):
if debug.enabled():
pprint('Discovered')
yield Service()
def check_myspecial_response_code(params, section):
yield Result(state=State.OK, summary="Found the service!")
register.check_plugin(
name="myspecial_response_code",
service_name="Myspecial - response code",
discovery_function=discovery_myspecial_response_code,
check_function=check_myspecial_response_code,
check_ruleset_name='myspecial',
check_default_parameters={'port': 20}
