CMK version:
Checkmk version 2.1.0p15
OS version:
- OS: Debian GNU/Linux 11 (bullseye)
- Kubernetes: v1.24.7+k3s1
[special_kube] Agent exited with code 1: could not convert string to float: '50M'(!!)
OMD[mwscan_site]:~$ cmk --debug -vvn k3sdev
Trying to acquire lock on /omd/sites/mwscan_site/var/check_mk/license_usage/next_run
Got lock on /omd/sites/mwscan_site/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/mwscan_site/var/check_mk/license_usage/history.json
Got lock on /omd/sites/mwscan_site/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mwscan_site/var/check_mk/license_usage/history.json
Released lock on /omd/sites/mwscan_site/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mwscan_site/var/check_mk/license_usage/next_run
Released lock on /omd/sites/mwscan_site/var/check_mk/license_usage/next_run
+ FETCHING DATA
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7fc2eb09c310]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(k3sdev, base_path=/omd/sites/mwscan_site/tmp/check_mk/data_source_cache/special_kube, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Does not exist)
Calling: /omd/sites/mwscan_site/share/check_mk/agents/special/agent_kube --pwstore=4@0@kubernetes_dev '--cluster' 'devcluster' '--token' '**********************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************************' '--monitored-objects' 'deployments' 'daemonsets' 'statefulsets' 'namespaces' 'nodes' 'pods' '--cluster-aggregation-exclude-node-roles' 'control-plane' 'infra' '--api-server-endpoint' 'https://kube-dev.iznet:6443' '--verify-cert-api' '--api-server-proxy' 'FROM_ENVIRONMENT' '--k8s-api-connect-timeout' '20' '--cluster-collector-endpoint' 'https://kube-dev.iznet/checkmk-collector/' '--verify-cert-collector' '--cluster-collector-proxy' 'FROM_ENVIRONMENT'
[cpu_tracking] Stop [7fc2eb09c310 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=1.41, children_system=0.13, elapsed=1.8599999994039536))]
[cpu_tracking] Start [7fc2eafbcc70]
[PiggybackFetcher] Fetch with cache settings: NoCache(k3sdev, base_path=/omd/sites/mwscan_site/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'k3sdev'. Skip processing.
[cpu_tracking] Stop [7fc2eafbcc70 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
-> Not adding sections: Agent exited with code 1: could not convert string to float: '50M'
No persisted sections
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fc2eafbc4c0]
value store: synchronizing
Trying to acquire lock on /omd/sites/mwscan_site/tmp/check_mk/counters/k3sdev
Got lock on /omd/sites/mwscan_site/tmp/check_mk/counters/k3sdev
Releasing lock on /omd/sites/mwscan_site/tmp/check_mk/counters/k3sdev
Released lock on /omd/sites/mwscan_site/tmp/check_mk/counters/k3sdev
[cpu_tracking] Stop [7fc2eafbc4c0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[special_kube] Agent exited with code 1: could not convert string to float: '50M'(!!), [piggyback] Missing data(!), execution time 1.9 sec | execution_time=1.860 user_time=0.000 system_time=0.010 children_user_time=1.410 children_system_time=0.130 cmk_time_ds=0.310 cmk_time_agent=0.000
