Hi there. I am trying to get a statistic for the time the host was OFF the internet.
No connection to host might be caused by different issues. So simply checking a connection to the host
will not do. Obviously when there is no internet connection, I will not be able to send anything (so I think that using a service will not do the trick).
I tried sending an event with timestamp (syslog format) (CONNECTED/DISCONNECTED) but then I cant find how to make a report for the time between the two events.
Any advice will be appreciated !
Best regards - Nick !
