Hi Team,
Can anyone please let us know if there is any MKP’s available to monitor Storage grids in checkmk. As checked, we don’t have option for now to setup monitoring for it. We are looking for any MKP’s are already for it.
Hi Team,
I saw that Storage Grid supports SNMP and as owned by NetApp might also support API based monitored. Have you tried any of those approaches?
We have tired with SNMP but there was no services related to storage grid was discovering. The existing Netapp in 2.4 enterprise edition didnot work for storage grids.
If i read the documentation correct than your StorageGrid is on the hardware level a SANtricity (Netapp eSeries) controller.
That means you can use the extension from @aeckstein here for the hardware monitoring.
Hi Andreas,
This didnot work and we get an error stating that service is unavailable.
Do you use the correct IP as the management controller has a different IP than your normal StorageGrid IP is.
Also what model do you have as there are different hardware models i think.
Hi!
I also have a StorageGrid System and I have written some REST-API checks for it. As it only monitors the values I was interested in, it is no complete monitoring solution for StorageGrid. If someone has such a thing, I would be interested in using it.
