TCP Connection check from agent side
Hello, imagine linux agent has a vpn connection and when vpn is up, 22 port 192.168.1.10 is accessible from agent. Now is it possible to create a TCP connection check on Checkmk server but tell Checkmk to run it from agent?
you can do this writing a local check: https://docs.checkmk.com/latest/en/localchecks.html
Karl
You can also use the nagios plugins with mpre configuration on agent site.
Christian
