I’m using Checkmk 1.6.0p19 raw edition.
I’m trying to add my Eaton UPS via SNMP monitoring. I added the UPS With “no agent, all configured special agents” and added the SNMP information. When I test SNMP, everything seems to work.
The problem is that the ups plugins (like ups_in_voltage) don’t get discovered for this host.
When I “force” to check the plugin with cmk, the service gets discovered and I can see the correct data in the GUI, but they are shown as “vanished”.
Does anybody has an idea where to look ? Why doens’t the GUI wants to use the ups plugins?
$ cmk --checks=ups_in_voltage -vvI nobreak.mysite.local
Discovering services on: nobreak.mysite.local
nobreak.mysite.local:
- FETCHING DATA
[snmp] No persisted sections loaded
[snmp] Not using cache (Don’t try it)
[snmp] Execute data source
[snmp] ups_in_voltage: Fetching data
Running ‘snmpwalk -v3 -l authNoPriv -a md5 -u mysite -A myupspass -m “” -M “” -Cc -OQ -OU -On -Ot 10.10.10.70 .1.3.6.1.2.1.33.1.3.3.1.3’
[snmp] Write data to cache file /omd/sites/mysite/tmp/check_mk/data_source_cache/snmp/nobreak.mysite.local
Try aquire lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/snmp/nobreak.mysite.local
Got lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/snmp/nobreak.mysite.local
Releasing lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/snmp/nobreak.mysite.local
Released lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/snmp/nobreak.mysite.local
[piggyback] No persisted sections loaded
No piggyback files for ‘nobreak.mysite.local’. Skip processing.
No piggyback files for ‘10.10.10.70’. Skip processing.
Loading autochecks from /omd/sites/mysite/var/check_mk/autochecks/nobreak.mysite.local.mk - EXECUTING DISCOVERY PLUGINS (1)
Trying discovery with: ups_in_voltage
Try aquire lock on /omd/sites/mysite/var/check_mk/autochecks/nobreak.mysite.local.mk
Got lock on /omd/sites/mysite/var/check_mk/autochecks/nobreak.mysite.local.mk
Releasing lock on /omd/sites/mysite/var/check_mk/autochecks/nobreak.mysite.local.mk
Released lock on /omd/sites/mysite/var/check_mk/autochecks/nobreak.mysite.local.mk
SUCCESS - Found no new services, no new host labels
