I am no expert in Python and i am using this plugin. I require this to work. Any help will be greatly appreciated.
The part of plugin
#!/usr/bin/python
def get_config():
config_dir = os.getenv("MK_CONFDIR", "/etc/check_mk")
config_file = config_dir + "/apache_status.conf"
if not os.path.exists(config_file):
config_file = config_dir + "/apache_status.cfg"
# None or tuple of ((proto, cacert), ipaddress, port, instance_name).
# - proto is 'http' or 'https'
# - cacert is a path to a CA certificate, or None
# - port may be None
# - instance_name may be the empty string
config = {
"servers": None,
"ssl_ports": [443],
if os.path.exists(config_file):
execfile(config_file, config)
return config
def try_detect_servers(ssl_ports):
results = []
for netstat_line in os.popen('netstat -tlnp 2>/dev/null').readlines():
parts = netstat_line.split()
# Skip lines with wrong format
if len(parts) < 7 or '/' not in parts[6]:
continue
server_address, server_port = parts[3].rsplit(':', 1)
server_port = int(server_port)
# Use localhost when listening globally
if server_address == '0.0.0.0':
server_address = '127.0.0.1'
elif server_address == '::':
server_address = '[::1]'
elif ':' in server_address:
server_address = '[%s]' % server_address
# Switch protocol if port is SSL port. In case you use SSL on another
# port you would have to change/extend the ssl_port list
if server_port in ssl_ports:
scheme = 'https'
else:
scheme = 'http'
results.append((scheme, server_address, server_port))
return results
def _unpack(config):
if isinstance(config, tuple):
if len(config) == 3:
# Append empty instance name.
config += ("",)
if not isinstance(config[0], tuple):
# Set cacert option.
config = ((config[0], None),) + config[1:]
return config + ("server-status",)
*return ((config['protocol'], config.get('cafile', None)), config['address'], config['port'],*
config.get("instance", ""), config.get('page', 'server-status'))
My config (apache-status.cfg)
servers = ['127.0.0.1']
ssl_ports = [443]
protocol=['https']
port=[443]
whatever changes i make here, it throws the same error.
Error:
File "./a", line 209, in <module>
sys.exit(main())
File "./a", line 186, in main
(proto, cafile), address, port, name, page = _unpack(server)
File "./a", line 141, in _unpack
TypeError: string indices must be integers, not str
