I try to code a plugin, but due to the lack of up to date documentation, this became a mess already …
so far i got most things sorted out, except how to use params inside checks …
I created the variable, I yielded it in the inventory like the tutorial suggested, but this just gives me “UNKNOWN - invalid output from agent or error in check implementation” in the webfront but no error in the console (‘check_mk --no-cache --checks bitbox_ram -I tom01-adm’)
I then found an option for the check_info (“default_levels_variable” : “ram_default_levels”) which at least gave me an empty dictionary as param “{}” but still not the variable i defined …
What am I missing? Is there any working documentation/tutorial?
ram_default_levels = (2, 1) # this is, what i would like to get as params in the check
def inventory_bitbox_ram(info):
for line in info:
yield line[0], "ram_default_levels"
def check_bitbox_ram(item, params, info):
warn, crit = params # this is an empty dict, even if it should not be :(
for line in info:
if item == line[0]:
perfdata= [("free", line[2], "", "", 0, line[1]),
("available", line[3], "", "", 0, line[1])]
if line[3] > warn:
return 0, "OK - %s RAM: %.2fGB available of %.2fGB (%.2fGB free)." % (line[0], line[3], line[1], line[2]), perfdata
elif line[3] > crit:
return 1, "WARNING - %s RAM: %.2fGB available of %.2fGB (%.2fGB free)." % (line[0], line[3], line[1], line[2]), perfdata
elif line[3] <= crit:
return 2, "CRITICAL - %s RAM: %.2fGB available of %.2fGB (%.2fGB free)." % (line[0], line[3], line[1], line[2]), perfdata
check_info["bitbox_ram"] = {
"snmp_scan_function" : scan_bitbox,
"parse_function" : parse_bitbox_ram,
"inventory_function" : inventory_bitbox_ram,
"check_function" : check_bitbox_ram,
"default_levels_variable" : "ram_default_levels", # without this, the whole check seems to not execute at all without any further information
"has_perfdata" : True,
"group" : "bitbox",
"service_description" : "RAM %s",
"snmp_info" : ( ".1.3.6.1.4.1.30205.18.1.1", ["1", "6", "7", "8"])
