is there an unregister command for agents to get removed from bakery? I haven’t found that so far. If there is no special command for this, is there a best practice for that?
you can find the per host registration info in the files below ~/var/check_mk/agent_deployment.
Just delete the desired host file and it is unregistered. But I don’t know for what purpose, except for cleanup.
Thank you for your answer. We have some older systems on windows where we cannot deploy the new agent. now we can cleanup the bakery from this systems.
