Hi all,
is it possible to use a custom host attribute in mail notification and third party script like telegram?
br
Dennis
Hi all,
br
Dennis
hi,
custom attribute set: “location”
set log level for notfications to “Full dump of all variables…” but there is no variable like “*_*LOCATION”
is it possible, that the variable is called “NOTIFY_HOST_LOCATION”?
BR
Dennis
just saw in variable list, HOSTLABELS could also beeing used for my case. Set a HOSTLABEL like “location:example” and used then “NOTIFY_HOSTLABEL_location” in telegram notify script. Works like expected…
@kdeutsch or would you say working with hostlabels for this usecase is not the preferred solution in cmk?
Hi @dns_es ,
that depends on the operational scenario: Custom host attributes are static, host labels are very dynamic. They can also arise at runtime from scripts, discovered processes, etc. I would probably rather do the solution with labels …
Karl
