Hi there,
I’ve just tried to migrate an instances from a VM ubuntu 16.04 to another one running ubuntu 18.04. Both get tg 1.6.0p11 raw version installed.
Issue 1 :
Exception: Unable to successfully perform the LDAP search (LDAP connection failed:
2020-05-26 17:30:02,249 [40] [cmk.web 25006] Exception (Admins, userdb_job): Traceback (most recent call last):
File "/omd/sites/ArchiMonitor/lib/python/cmk/gui/userdb.py", line 1380, in _execute_sync_action
connection.do_sync(add_to_changelog=add_to_changelog, only_username=False)
File "/omd/sites/ArchiMonitor/lib/python/cmk/gui/plugins/userdb/ldap_connector.py", line 1159, in do_sync
ldap_users = self.get_users()
File "/omd/sites/ArchiMonitor/lib/python/cmk/gui/plugins/userdb/ldap_connector.py", line 793, in get_users
self._config['user_scope']):
File "/omd/sites/ArchiMonitor/lib/python/cmk/gui/plugins/userdb/ldap_connector.py", line 646, in _ldap_search
_('Unable to successfully perform the LDAP search (%s)') % last_exc)
MKLDAPException: Unable to successfully perform the LDAP search (LDAP connection failed:
On the new server, the ldap connection is running well on a new instance. The problem is coming only on the migrated instance.
Issue 2:
PHP Error on Nagvis.
Error: (0) Trying to access array offset on value of type int
URL: /ArchiMonitor/nagvis/server/core/ajax_handler.php?mod=Map&act=getMapObjects&show=Anneau&sources=dynmap&header_menu=1&hover_menu=1&context_menu=1&zoom=100&dynmap_init_x=20&dynmap_init_y=700&dynmap_offset_x=30&dynmap_offset_y=30&dynmap_per_row=30&dynmap_sort=a&dynmap_order=asc&_ajaxid=1590505965
File: /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/classes/GlobalMapCfg.php
Line: 970
#0 /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/classes/GlobalMapCfg.php(970): nagvisExceptionErrorHandler()
#1 /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/classes/GlobalMapCfg.php(489): GlobalMapCfg->verifyObjectIds()
#2 /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/classes/CoreModMap.php(322): GlobalMapCfg->readMapConfig()
#3 /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/classes/CoreModMap.php(105): CoreModMap->getMapObjects()
#4 /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/functions/index.php(120): CoreModMap->handleAction()
#5 /opt/omd/versions/1.6.0p11.cre/share/nagvis/htdocs/server/core/ajax_handler.php(59): require('/opt/omd/versio...')
#6 {main}
So on the old VM php version is 7.0.33-0ubuntu0.16.04.14 and PHP 7.4.6 on the new one.
I didn’t found any point about migrating on a new OS version in the official documentation. Anybody could tell me if there’s best practice to make this sort of migration?
Thanks for help
