CMK version: 1.5.0p11
OS version: Ubuntu 18.04
Error message: So I’ve created a rule for the “Patch state” check which defaults to (warn/crit 45/90)
, and have overridden it to (45/3652)
. However, the checks are still saying CRIT ... (warn/crit 45/90)
. This is even after I’ve rescheduled the active checks on them.
When I dig into a particular alert, I can see that the Parameters page, the “Type of Check” field is pointing to that overriding rule (it says Rule 1 in Main Directory), however, from what I see above, it is not getting applied.
What must I do to have these CRIT alerts changed to WARN alerts per the parameters I set above in the Rule override?
