What is the format for winperf check_mk.ini counters for using “names” and counters by section? Or is all of this going to change radically in 1.7? I want to monitor (graph) DNS requests/sec.
Hallo Johannes,
auf dem Checkmk Server gibt es unter WATO Agents -> Agent files eine check_mk.ini Datei. Da stehen auch Beispiele für winperf drin.
Die check_mk.ini nutzt der ‘alte Agent’ der neue Agent nutzt die .yml Dateien. Auch diese Datei findest in WATO.
Viele Grüße
Anastasios
What confused me was the hierarchical path nature of individual counters. In winperf you want the “Windows Section” as the id and that will give you all the counters under that section.
So, in my case, in the .yml file I needed:
counters:
- DNS: cjc_dns
(where I use “cjc”, my initials, to denote things I’m testing)
