I am managing an installation done by a colleague quite a white ago. Its a multisite setup, using only one instance though.
I would like to change the basic logon to the html form but I am unable to find out where to find this setting.
When I create a new instance with omd, the new site uses the html form.
Please be kind with this noob
you could search for Auth in files under /omd/sites/yoursite/etc/apache/ where yoursite is the name of the site with http auth. You also could compare etc/apache/ folder of both sites (the one with http auth and the one with html form).
Thanks for this suggestion, but I digged through nearly every file under /opt/omd/sites/mysite and /opt/omd/sites/testsite and found no differences!
This is what /opt/omd/sites/mysite/apache/conf.d/auth.conf looks like:
# General auth configuration for this site
<Location "/mysite">
Order allow,deny
Allow from all
AuthName "OMD Monitoring"
AuthType Basic
AuthUserFile /omd/sites/mysite/etc/htpasswd
require valid-user
</Location>
The config of the new site is exactly the same (except the sitename of course)
I changed the Test in AuthName to see it changes the output of the prompt, but it didnāt.
As the Text here is like "OMD Monitoring sitename" I guess it comes from /opt/omd/versions/1.4.0p23.cre/share/omd/htdocs/logout.php
