Aber Inventory über WATO am Master - logisch ist anders also:
$ cmk --debug -II -vv server
Discovering services and host labels on: server
server:
+ FETCHING DATA
[cpu_tracking] Start [7fcfb81ac1f0]
Connecting via TCP to 127.0.0.1:6556 (5.0s timeout)
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(base_path=PosixPath('/omd/sites/site/tmp/check_mk/cache/server'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Using data from cache file /omd/sites/site/tmp/check_mk/cache/server
Got 62587 bytes data from cache
[TCPFetcher] Use cached data
Closing TCP connection to 127.0.0.1:6556
[cpu_tracking] Stop [7fcfb81ac1f0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7fcfb81ac580]
No piggyback files for 'server'. Skip processing.
No piggyback files for '127.0.0.1'. Skip processing.
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath('/omd/sites/site/tmp/check_mk/data_source_cache/piggyback/server'), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7fcfb81ac580 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
Loading autochecks from /omd/sites/site/var/check_mk/autochecks/server.mk
Trying to acquire lock on /omd/sites/site/var/check_mk/persisted/server
Got lock on /omd/sites/site/var/check_mk/persisted/server
Releasing lock on /omd/sites/site/var/check_mk/persisted/server
Released lock on /omd/sites/site/var/check_mk/persisted/server
Stored persisted sections: lnx_packages, lnx_distro, lnx_cpuinfo, dmidecode, lnx_uname, lnx_ip_r, lnx_sysctl, lnx_block_devices
Using persisted section SectionName('lnx_packages')
Using persisted section SectionName('lnx_distro')
Using persisted section SectionName('lnx_cpuinfo')
Using persisted section SectionName('dmidecode')
Using persisted section SectionName('lnx_uname')
Using persisted section SectionName('lnx_ip_r')
Using persisted section SectionName('lnx_sysctl')
Using persisted section SectionName('lnx_block_devices')
-> Add sections: ['apt', 'check_mk', 'chrony', 'cifsmounts', 'cmk_site_statistics', 'cpu', 'df', 'diskstat', 'dmidecode', 'job', 'kernel', 'labels', 'livestatus_ssl_certs', 'livestatus_status', 'lnx_block_devices', 'lnx_cpuinfo', 'lnx_distro', 'lnx_if', 'lnx_ip_r', 'lnx_packages', 'lnx_sysctl', 'lnx_uname', 'local', 'logwatch', 'md', 'mem', 'mkeventd_status', 'mknotifyd', 'mounts', 'nfsmounts', 'omd_apache', 'omd_info', 'omd_status', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest', 'wireguard']
No persisted sections loaded
-> Add sections: []
Received no piggyback data
+ EXECUTING HOST LABEL DISCOVERY
Trying host label discovery with: apt, check_mk, chrony, cifsmounts, cmk_site_statistics, cpu, df, diskstat, dmidecode, job, kernel, labels, livestatus_ssl_certs, livestatus_status, lnx_block_devices, lnx_cpuinfo, lnx_distro, lnx_if, lnx_ip_r, lnx_packages, lnx_sysctl, lnx_uname, local, logwatch, md, mem, mkeventd_status, mknotifyd, mounts, nfsmounts, omd_apache, omd_info, omd_status, ps_lnx, systemd_units, tcp_conn_stats, uptime, vbox_guest, wireguard
cmk/os_family: linux (check_mk)
cmk/device_type: vm (labels)
cmk/check_mk_server: yes (omd_info)
+ PERFORM HOST LABEL DISCOVERY
Trying to acquire lock on /omd/sites/site/var/check_mk/discovered_host_labels/server.mk
Got lock on /omd/sites/site/var/check_mk/discovered_host_labels/server.mk
Releasing lock on /omd/sites/site/var/check_mk/discovered_host_labels/server.mk
Released lock on /omd/sites/site/var/check_mk/discovered_host_labels/server.mk
+ EXECUTING DISCOVERY PLUGINS (41)
Trying discovery with: mkeventd_status, mounts, omd_apache, check_mk_only_from, domino_tasks, livestatus_status, omd_status, cpu_loads, systemd_units_services_summary, logwatch_ec_single, kernel_performance, mknotifyd, mknotifyd_connection, local, job, mem_win, nfsmounts, mem_vmalloc, cpu_threads, vbox_guest, md, kernel_util, mem_linux, logwatch_ec, check_mk_agent_update, cifsmounts, tcp_conn_stats, docker_container_status_uptime, logwatch_groups, k8s_stats_network, kernel, logwatch, df, uptime, cmk_site_statistics, lnx_if, chrony, apt, systemd_units_services, ps, diskstat
Trying to acquire lock on /omd/sites/site/var/check_mk/autochecks/server.mk
Got lock on /omd/sites/site/var/check_mk/autochecks/server.mk
Releasing lock on /omd/sites/site/var/check_mk/autochecks/server.mk
Released lock on /omd/sites/site/var/check_mk/autochecks/server.mk
1 apt
1 check_mk_agent_update
1 chrony
1 cmk_site_statistics
1 cpu_loads
1 cpu_threads
1 df
1 diskstat
1 kernel_performance
1 kernel_util
1 livestatus_status
3 lnx_if
4 logwatch
1 mem_linux
1 mkeventd_status
1 mknotifyd
1 mounts
1 omd_apache
1 omd_status
1 ps
1 systemd_units_services_summary
1 tcp_conn_stats
1 uptime
SUCCESS - Found 28 services, 3 host labels
Auch ohne Cache-File bleibt das Ergebnis das selbe.
