I found a problem while deploying custom files with the bakery.
If I deploy a plugin for example ibm_mq with the bakery the permission on the target server are 0755.
-rwxr-xr-x. 1 root root 2902 4. Nov 09:52 ibm_mq
But if I deploy a custom file then the permission are 0751 allthough the source file ist 0755. This is no problem if the plugin runs with root user. But if you have a plugins which calls it self to use a non root user then you get “permission denied”.
-rwxr-x–x. 1 root root 5590 11. Nov 10:40 sas_status_as
Is this a bug, or the expected behaviour.
Regards
Christoph
