Hello!!!
I am having a problem with the storeonce plugin. The storeonce data does not match the raw checkmk 1.6.0p9. For example Total Capacity put PB Store eleven
Name value
Total Capacity 29.91TB
Free Space 29.42 TB
Used Space 488.77 GB
Status Mounted
checkmk
Total Capacity 1.63% used (227.6 TB of 13.6 PB), trend +4.34 GB / 24 hours
I want to know if it is a plugin problem or mine . I don´t know if I am missing something to configure. Another thing that strikes me is that there are very few recognized services.
Any help I appreciate a lot.
That is ok if the storage is new and empty
I saw a difference between my system and the actual 1.6 inside the check function.
At the moment i have no possibility to test if there is a bug inside the actual 1.6 version.
The user bytes i think are not so important as only the capacity and free bytes are used inside the check.
But i cannot say correctly as i cannot access my storeonce at the moment.
I don’t know why the factor is “1024 * 2” it should be “1024 * 1024”.
This error was introduce two years before with Werk 6488.
In my system i use the old version before this werk that’s why i have a correct value
