We plan to create some additional plugins and active checks and would like to have them grouped by one or more additional sections, e.g in “Other services” (Setup > Services > Other Services), or even better directly at “Setup > Services”.
Is that somehow possible? How?
Thanks a lot and a happy new year to you!
Christian
It should be possible to declare your own section like this one.
@rulespec_group_registry.register
class RulespecGroupIntegrateMyCompany(RulespecGroup):
@property
def name(self):
return "company_checks"
@property
def title(self):
return _("Company services")
@property
def help(self):
return _("This services are provided by so called company checks. ")
For sub groups the definition looks a little bit different but it should also be possible.
I’ve (finally) found some time to try this but failed.
First issue is that I have no idea to which file I have to add this new class… for a test I’ve added it to my plugin configuration script in~/local/share/check_mk/web/plugins/wato/. But this doesn’t help, the result was that the check configuration disappeared
So, what I now assume is that this list:
is somewhere statically defined and (currently) cannot be extended.
Anyone from the CheckMk team here who can confirm this?
