CMK version: 2.0.0p39 (CEE)
OS version Ubuntu 22.04:
I tried to create a custom SNMP check with the help of this article:
Writing SNMP-based check plug-ins (checkmk.com)
For a first test I only changed the to be detected sysDescr. string to Cisco.
The output of snmpwalk for this is SNMPv2-MIB::sysDescr.0 = STRING: Cisco IOS Software [Cupertino], Catalyst L3 Switch Software…
But even with the sample code I just get nothing in return if I try to run it via:
cmk -vvvI --detect-plugins=flintstone_setup_check.py --debug MYDEVICE
Discovering services and host labels on: MYDEVICE
MYDEVICE:
- FETCHING DATA
[cpu_tracking] Start [7f8061f23250]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(base_path=PosixPath(‘/omd/sites/mysite/tmp/check_mk/data_source_cache/snmp/MYDEVICE’), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Mode Mode.FORCE_SECTIONS)
[cpu_tracking] Stop [7f8061f23250 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[cpu_tracking] Start [7f8061f23610]
[PiggybackFetcher] Fetch with cache settings: NoCache(base_path=PosixPath(‘/omd/sites/mysite/tmp/check_mk/data_source_cache/piggyback/MYDEVICE’), max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
No piggyback files for ‘MYDEVICE’. Skip processing.
No piggyback files for ‘1.2.3.4’. Skip processing.
[cpu_tracking] Stop [7f8061f23610 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
- PARSE FETCHER RESULTS
No persisted sections loaded
→ Add sections:
Loading autochecks from /omd/sites/mysite/var/check_mk/autochecks/MYDEVICE.mk
→ Add sections:
Received no piggyback data
- EXECUTING HOST LABEL DISCOVERY
Trying host label discovery with:
PERFORM HOST LABEL DISCOVERY
EXECUTING DISCOVERY PLUGINS (0)
Trying discovery with:
Trying to acquire lock on /omd/sites/mysite/var/check_mk/autochecks/MYDEVICE.mk
Got lock on /omd/sites/mysite/var/check_mk/autochecks/MYDEVICE.mk
Releasing lock on /omd/sites/mysite/var/check_mk/autochecks/MYDEVICE.mk
Released lock on /omd/sites/mysite/var/check_mk/autochecks/MYDEVICE.mk
SUCCESS - Found no new services, no new host labels
What I am doing wrong?
