[2.0.0p9] Problem dashboard shows historical data?
This is my current view of the “Problem dashboard”, especiallcy the “Events of the recent 4 hours”:
But all these “Summary”'s are historical. None of that servers actually had thise problems in the displayed time. Example: The “Agent Bakery” errors are all from last Friday (17.09). The Agent bakery overview says, that everything since then was okay.
A detail view of one host from there:
That seems to not be true. “Last update check” is definitely wrong here!
All the affected hosts are managed by a remote site (centralized management).
Did I missed something?
Yep, every remote managed host periodically send the same events. In the same order. All local hosts does not show this behaviour:
On the remote site what events do you see there for this host? Not only the notifications but all the other events for this host.
God dammit! The remote site’s mail config was misconfigured. I did not noticed, that these are tries to send an email which are failing.
Corrected it - CMK is now sending mails.
It was unclear, that there was an error using sendmial to send those mails away.
