CMK version: 2.1.0p11
(image digest: 42f32e675ab8)
OS version:
Debian 10 (buster) - inside the container
Host is running Ubuntu 20.04.5 LTS, and Docker version 20.10.18, build b40c2f6
ERROR [cmk_agent_ctl] Failed to run as user 'cmk-agent'. Please execute with sufficient permissions (maybe try 'sudo').
Caused by:
Could not find dedicated Checkmk agent user cmk-agent
cmk debug output
OMD[cmk]:~$ cmk --debug -vvn localhost
Checkmk version 2.1.0p11
Trying to acquire lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
Got lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Got lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Released lock on /omd/sites/cmk/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
Released lock on /omd/sites/cmk/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f0749cf1b50]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(localhost, base_path=/omd/sites/cmk/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 53 sec, allowed is 0 sec)
Connecting via TCP to 127.0.0.1:6556 (5.0s timeout)
Reading data from agent
Write data to cache file /omd/sites/cmk/tmp/check_mk/cache/localhost
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/cache/localhost
Got lock on /omd/sites/cmk/tmp/check_mk/cache/localhost
Releasing lock on /omd/sites/cmk/tmp/check_mk/cache/localhost
Released lock on /omd/sites/cmk/tmp/check_mk/cache/localhost
Closing TCP connection to 127.0.0.1:6556
[cpu_tracking] Stop [7f0749cf1b50 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.47999999672174454))]
[cpu_tracking] Start [7f0749ce0fa0]
[PiggybackFetcher] Fetch with cache settings: NoCache(localhost, base_path=/omd/sites/cmk/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'localhost'. Skip processing.
No piggyback files for '127.0.0.1'. Skip processing.
[cpu_tracking] Stop [7f0749ce0fa0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<docker_container_mem>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_container_cpu>>> / Transition HostSectionParser -> HostSectionParser
<<<docker_container_diskstat>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<livestatus_status:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<livestatus_ssl_certs:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<mkeventd_status:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<cmk_site_statistics:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
<<<omd_status:cached(1663099775,60)>>> / Transition HostSectionParser -> HostSectionParser
<<<mknotifyd:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<omd_apache:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<omd_info:sep(59)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
-> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cmk_site_statistics', 'docker_container_cpu', 'docker_container_diskstat', 'docker_container_mem', 'job', 'labels', 'livestatus_ssl_certs', 'livestatus_status', 'lnx_if', 'local', 'md', 'mkeventd_status', 'mknotifyd', 'mounts', 'nfsmounts', 'omd_apache', 'omd_info', 'omd_status', 'postfix_mailq', 'postfix_mailq_status', 'ps_lnx', 'tcp_conn_stats', 'uptime', 'vbox_guest']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f0749ce0190]
value store: synchronizing
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/counters/localhost
Got lock on /omd/sites/cmk/tmp/check_mk/counters/localhost
Releasing lock on /omd/sites/cmk/tmp/check_mk/counters/localhost
Released lock on /omd/sites/cmk/tmp/check_mk/counters/localhost
CPU utilization Total CPU: 4.03%
Check_MK Agent Version: 2.1.0p11, OS: linux, Agent plugins: 0, Local checks: 0
Disk IO SUMMARY Read: 0.00 B/s, Write: 9.18 kB/s
Interface 2 [eth0], (up), MAC: 02:42:AC:12:00:02, Speed: 10 GBit/s, In: 0.00 B/s (0%), Out: 0.00 B/s (0%)
MD Softraid md0 Status: active, Spare: 0, Failed: 0, Active: 2, Status: 2/2, UU
MD Softraid md1 Status: active, Spare: 0, Failed: 0, Active: 2, Status: 2/2, UU
Memory RAM: 1.17% - 751 MiB of 62.7 GiB
Mount options of /opt/omd/sites Mount options exactly as expected
OMD cmk Event Console Current events: 0, Virtual memory: 178.79 MB, Overall event limit inactive, No hosts event limit active, No rules event limit active, Received messages: 0.00/s, Rule hits: 0.00/s, Rule tries: 0.00/s, Message drops: 0.00/s, Created events: 0.00/s, Client connects: 0.02/s, Rule hit ratio: -, Processing time per message: -, Time per client request: 0.21 ms
OMD cmk apache 0.02 Requests/s, 0.00 Seconds serving/s, 0.06 B Sent/s
OMD cmk performance Livestatus version: 2.1.0p11, Host checks: 0.0/s, Service checks: 0.3/s
OMD cmk status running
Postfix Queue Deferred queue length: 0, Active queue length: 0
Site cmk statistics Total hosts: 1, Problem hosts: 0, Total services: 19, Problem services: 0
TCP Connections Established: 2
Uptime Up since Sep 13 2022 15:46:58, Uptime: 6 hours 24 minutes
+ EXECUTING INVENTORY PLUGINS
aruba_wlc_aps: skipped (no data)
check_mk: ok
check_mk: skipped (no data)
checkmk_agent_plugins: ok
checkmk_agent_plugins: skipped (no data)
docker_node_info: skipped (no data)
fritz: skipped (no data)
hp_proliant_da_phydrv: skipped (no data)
hp_proliant_mem: skipped (no data)
ibm_mq_channels: skipped (no data)
ibm_mq_managers: skipped (no data)
ibm_mq_queues: skipped (no data)
ipmi_firmware: skipped (no data)
inv_cisco_vlans: skipped (no data)
inv_esx_vsphere_hostsystem: skipped (no data)
inv_if: ok
inv_if: skipped (no data)
aix_packages: skipped (no data)
aix_service_packs: skipped (no data)
inventory_checkmk: ok
inventory_checkmk: skipped (no data)
checkpoint_vpn_tunnels: skipped (no data)
dmidecode: skipped (no data)
docker_container_labels: skipped (no data)
docker_container_network: skipped (no data)
docker_node_images: skipped (no data)
docker_node_network: skipped (no data)
inventory_esx_vsphere_clusters: skipped (no data)
inventory_esx_vsphere_virtual_machines: skipped (no data)
fortiauthenticator_system: skipped (no data)
fortigate_ha: skipped (no data)
fortimail_system: skipped (no data)
fortisandbox_software: skipped (no data)
fortisandbox_system: skipped (no data)
k8s_assigned_pods: skipped (no data)
k8s_daemon_pod_containers: skipped (no data)
k8s_endpoint_info: skipped (no data)
k8s_ingress_infos: skipped (no data)
k8s_job_container: skipped (no data)
kube_cluster: skipped (no data)
kube_daemonset: skipped (no data)
kube_deployment: skipped (no data)
kube_namespace: skipped (no data)
kube_node: skipped (no data)
kube_pod: skipped (no data)
kube_statefulset: skipped (no data)
lnx_block_devices: skipped (no data)
lnx_ip_r: skipped (no data)
lnx_packages: skipped (no data)
lnx_sysctl: skipped (no data)
lnx_video: skipped (no data)
mobileiron_inventory: skipped (no data)
mssql_clusters: skipped (no data)
oracle_systemparameter: skipped (no data)
snmp_extended_info: skipped (no data)
solaris_addresses: skipped (no data)
solaris_pkginfo: skipped (no data)
solaris_psrinfo: skipped (no data)
solaris_cpus: skipped (no data)
solaris_prtpicl: skipped (no data)
solaris_routes: skipped (no data)
statgrab_net: skipped (no data)
win_disks: skipped (no data)
win_exefiles: skipped (no data)
win_ip_r: skipped (no data)
win_networkadapter: skipped (no data)
win_reg_uninstall: skipped (no data)
win_video: skipped (no data)
win_wmi_software: skipped (no data)
win_wmi_updates: skipped (no data)
juniper_info: skipped (no data)
k8s_nodes: skipped (no data)
k8s_pod_container: skipped (no data)
k8s_roles: skipped (no data)
lnx_if: ok
lnx_if: skipped (no data)
mem_used: ok
mem_used: skipped (no data)
mssql_instance: skipped (no data)
netapp_api_disk: skipped (no data)
oracle_dataguard_stats: skipped (no data)
oracle_instance: skipped (no data)
oracle_performance: skipped (no data)
oracle_recovery_area: skipped (no data)
oracle_tablespaces: skipped (no data)
perle_chassis_slots: skipped (no data)
perle_psmu: skipped (no data)
snmp_info: skipped (no data)
winperf_if: skipped (no data)
aix_baselevel: skipped (no data)
aix_lparstat_inventory: skipped (no data)
allnet_ip_sensoric: skipped (no data)
citrix_controller: skipped (no data)
citrix_state: skipped (no data)
couchbase_nodes_ports: skipped (no data)
dell_hw_info: skipped (no data)
docker_container_node_name: skipped (no data)
esx_systeminfo: skipped (no data)
fireeye_sys_status: skipped (no data)
hp_proliant_systeminfo: skipped (no data)
infoblox_osinfo: skipped (no data)
infoblox_systeminfo: skipped (no data)
k8s_pod_info: skipped (no data)
k8s_selector: skipped (no data)
k8s_service_info: skipped (no data)
lnx_cpuinfo: skipped (no data)
lnx_distro: skipped (no data)
lnx_uname: skipped (no data)
lparstat_aix: skipped (no data)
netapp_api_info: skipped (no data)
perle_chassis: skipped (no data)
prtconf: skipped (no data)
snmp_os: skipped (no data)
snmp_quantum_storage_info: skipped (no data)
solaris_prtdiag: skipped (no data)
solaris_uname: skipped (no data)
suseconnect: skipped (no data)
win_bios: skipped (no data)
win_computersystem: skipped (no data)
win_cpuinfo: skipped (no data)
win_os: skipped (no data)
win_system: skipped (no data)
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost
Got lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost
Releasing lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost
Released lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost.gz
Got lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost.gz
Releasing lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost.gz
Released lock on /omd/sites/cmk/tmp/check_mk/status_data/localhost.gz
Trying to acquire lock on /omd/sites/cmk/tmp/check_mk/status_data/.last
Got lock on /omd/sites/cmk/tmp/check_mk/status_data/.last
Releasing lock on /omd/sites/cmk/tmp/check_mk/status_data/.last
Released lock on /omd/sites/cmk/tmp/check_mk/status_data/.last
[cpu_tracking] Stop [7f0749ce0190 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.009999999999999995, children_user=0.0, children_system=0.0, elapsed=0.019999995827674866))]
[agent] Success, execution time 0.5 sec | execution_time=0.500 user_time=0.010 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.480
Hey guys!
I’m new to checkmk, just learned about this project yesterday, and it looks very interesting! Right now I’m playing around with the raw version, and running it as a docker container.
While going through this guide:
I got stuck at this command:
cmk-agent-ctl register --hostname localhost --server linux --site cmk --user cmkadmin
It fails with the error mentioned above, Failed to run as user 'cmk-agent'
. And I can see that this user does not exist inside the container: cat /etc/passwd | grep cmk-agent
outputs nothing.
Googling gave me this article, that explains how this user is created: Checkmk agent with systemd creates dedicated system user
I tried re-installing the check-mk-agent inside the container:
dpkg -i /opt/omd/versions/2.1.0p11.cre/share/check_mk/agents/check-mk-agent_2.1.0p11-1_all.deb
And the output indicates that the user should not be created:
Preparing to unpack .../check-mk-agent_2.1.0p11-1_all.deb ...
Unpacking check-mk-agent (2.1.0p11-1) over (2.1.0p11-1) ...
Setting up check-mk-agent (2.1.0p11-1) ...
systemd not found on this system
Deployed xinetd
Which makes sense, since there’s no systemd inside the container.
I also trying creating the user manualy:
adduser --disabled-password --disabled-login --home /var/lib/cmk-agent cmk-agent
But it doesn’t help as well:
ERROR [cmk_agent_ctl] Something seems wrong with the agent socket (/run/check-mk-agent.socket), aborting```
If I als run the daemon:
```cmk-agent-ctl daemon &```
It starts responding to status command, but still won't register the node:
```root@adfb306b5d58:/# cmk-agent-ctl status
Version: 2.1.0p11
Agent socket: inoperational (!!)
IP allowlist: any
No connections
root@adfb306b5d58:/# cmk-agent-ctl register --hostname localhost --server linux --site cmk --user cmkadmin
Is this a bug inside the docker image? Or am I doing something wrong? Thanks!
