I cannot make agents working with the new “registration” feature.
Ubuntu 18.04 with systemd 237
The register command exists without giving any output after:
Y
and the cmk-agent-ctl status says:
Version: 2.1.0p2
Agent socket: operational
IP allowlist: any
Connection: [...]:8000/mk
UUID: b6947f24-[...]
Local:
Connection type: pull-agent
Certificate issuer: Site 'mk' local CA
Certificate validity: Wed, 08 Jun 2022 14:28:28 +0000 - Mon, 09 Oct 3020 14:28:28 +0000
Remote:
Registration state: operational
Host name: [...]
But the same was happening in p1 even if there was a permission issue, after updating to p2 I saw that error and fixed it by giving more permissions until the error has disappeared, I tried with admin login as well, but it’s the same…
In my case I had the xinetd services (from the old agents) still running. I had to uninstall xinetd (removing the configuration files first) and then uninstall and reinstall the agent. Since than the connection is established, stable and TLS secured.
thanks, unfortunately I already removed xinetd time ago, replaced with systemd first and now I’m trying with the new agent… I correctly have cmk-agent-ctl listening on 6556:
even if I telnet 127.0.0.1 6556 I get the agent output. Here I cannot remove xinetd, because if I try it says it will remove check-mk-raw-2.1.0p2 and all the dependencies as well.
On the server you can remove xinetd (with check-mk) and immidate reinstall check-mk after that.
Be sure, that you have a good backup, first .
On linux hosts the agent deactivates xinetd configuration automatically, but we saw still xinetd services running which prevent the agent-service from starting.
systemctl
should list the services in “running”
cmk-agent-ctl-daemon.service loaded active running Checkmk agent controller daemon
check-mk-agent-async.service loaded active running Checkmk agent - Asynchronous background tasks
Thank you, unfortunately it didn’t work, after remove + reinstall I still have xinetd, I also spawned a new instance with Ubuntu 22, but I have xinetd installed:
on the clients, I removed xinetd with apt purge xinetd so it’s not running (systemctl | grep xine shows nothing), I have these services running:
system-check\x2dmk\x2dagent.slice loaded active active system-check\x2dmk\x2dagent.slice
check-mk-agent.socket loaded active listening Local Checkmk agent socket
Since I’m still struggling with this issue, I have spawned a brand new server with Ubuntu 22, installed checkmk raw, switched the public IP from the old server to the new one (got hundreds of monitored servers with a firewall rule to allow 6556 to that IP only), configured apache to have SSL, then imported the backup from the old server (with omd backup + omd restore)
Then I installed the agent on the server, and registered, and this part finally worked, the server can monitor itself (even if I don’t understand why cmk-agent-ctl register --hostname 127.0.0.1 gave 404 Not Found: Host 127.0.0.1 does not exist., I had to put the public hostname).
However, all the other hosts doesn’t work, I see the same issue as before…
To recap, the issue is the following:
ss -tulpn says cmk-agent-ctl is listening on 6556
register command is successful (status says Remote: Connection type: pull-agent, Registration state: operational) but the monitoring host doesn’t get any output (no unmonitored services found, 18 vanished services)
If I do cmk-agent-ctl delete-all --enable-insecure-connections it works again but I have the annoying WARN TLS is not activated on monitored host
I think this whole TLS thing should be optional without showing any warning, since there are much simpler ways to secure the connection, like a simple firewall rule: ufw allow from 1.2.3.4 to any port 6556 proto tcpEDIT: I found I can do this in Setup>Services>Service monitoring rules>Checkmk Agent installation auditing>New rule: Checkmk Agent installation auditing
