[2.3.0p9cee] Monitor ADSL line via SNMP
Hi.
I have a DrayTek Vigor 167 and wanted to monitor it via SNMP. The basics are working but the DrayTek holöds much more OIDs than CMK support.
I found the MKP Checkmk Exchange which has an issue for 167 (Vigor167 Support · Issue #10 · f-zappa/check_mk_adsl_line · GitHub), so I thought maybe I can add the MIB for the ADSL standard?
So I uploaded the MIB (https://www.circitor.fr/Mibs/Mib/A/ADSL-LINE-MIB.mib) to the Event Console but it seems that this is not being used for SNMP check?
How can I add ADSL support for SNMP - or - could CMK support ADSL Line via SNMP?
cmk -vvv
value store: synchronizing
Trying to acquire lock on /omd/sites/l22/tmp/check_mk/counters/draytek
Got lock on /omd/sites/l22/tmp/check_mk/counters/draytek
Releasing lock on /omd/sites/l22/tmp/check_mk/counters/draytek
Released lock on /omd/sites/l22/tmp/check_mk/counters/draytek
Checkmk version 2.3.0p9
+ FETCHING DATA
 Source: SourceInfo(hostname='draytek', ipaddress='192.168.1.2', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f74617e0290]
Read from cache: SNMPFileCache(draytek, path_template=/omd/sites/l22/tmp/check_mk/data_source_cache/snmp/{mode}/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 23 sec, allowed is 0 sec)
 SNMP scan:
      Getting OID .1.3.6.1.2.1.1.1.0: Executing SNMP _Mode.GET of .1.3.6.1.2.1.1.1.0 on draytek
=> [b'DrayTek Corporation, Router Model: Vigor167, Version: 5.2.4, Build Date/Time: Thu Jan 18 11:23:14 CST 2024'] OCTETSTR
      Getting OID .1.3.6.1.2.1.1.2.0: Executing SNMP _Mode.GET of .1.3.6.1.2.1.1.2.0 on draytek
=> [b'.1.3.6.1.4.1.7367'] OBJECTID
      Using cached OID .1.3.6.1.2.1.1.1.0: 'DrayTek Corporation, Router Model: Vigor167, Version: 5.2.4, Build Date/Time: Thu Jan 18 11:23:14 CST 2024'
      Using cached OID .1.3.6.1.2.1.1.2.0: '.1.3.6.1.4.1.7367'
  SNMP scan found                    hr_mem snmp_uptime
Trying to acquire lock on /omd/sites/l22/tmp/check_mk/snmp_scan_cache/draytek.192.168.1.2
Got lock on /omd/sites/l22/tmp/check_mk/snmp_scan_cache/draytek.192.168.1.2
Releasing lock on /omd/sites/l22/tmp/check_mk/snmp_scan_cache/draytek.192.168.1.2
Released lock on /omd/sites/l22/tmp/check_mk/snmp_scan_cache/draytek.192.168.1.2
hr_cpu: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.3.3.1.2" on draytek
.1.3.6.1.2.1.25.3.3.1.2.196608 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.25.3.3.1.2.196609 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.25.3.3.1.2.196610 => [b'0'] 'INTEGER'
.1.3.6.1.2.1.25.3.3.1.2.196611 => [b'2'] 'INTEGER'
hr_mem: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.2.3.1.2" on draytek
.1.3.6.1.2.1.25.2.3.1.2.1 => [b'.1.3.6.1.2.1.25.2.1.2'] 'OBJECTID'
.1.3.6.1.2.1.25.2.3.1.2.3 => [b'.1.3.6.1.2.1.25.2.1.3'] 'OBJECTID'
.1.3.6.1.2.1.25.2.3.1.2.6 => [b'.1.3.6.1.2.1.25.2.1.1'] 'OBJECTID'
.1.3.6.1.2.1.25.2.3.1.2.7 => [b'.1.3.6.1.2.1.25.2.1.1'] 'OBJECTID'
.1.3.6.1.2.1.25.2.3.1.2.8 => [b'.1.3.6.1.2.1.25.2.1.1'] 'OBJECTID'
.1.3.6.1.2.1.25.2.3.1.2.10 => [b'.1.3.6.1.2.1.25.2.1.3'] 'OBJECTID'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.2.3.1.3" on draytek
.1.3.6.1.2.1.25.2.3.1.3.1 => [b'Physical memory'] 'OCTETSTR'
.1.3.6.1.2.1.25.2.3.1.3.3 => [b'Virtual memory'] 'OCTETSTR'
.1.3.6.1.2.1.25.2.3.1.3.6 => [b'Memory buffers'] 'OCTETSTR'
.1.3.6.1.2.1.25.2.3.1.3.7 => [b'Cached memory'] 'OCTETSTR'
.1.3.6.1.2.1.25.2.3.1.3.8 => [b'Shared memory'] 'OCTETSTR'
.1.3.6.1.2.1.25.2.3.1.3.10 => [b'Swap space'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.2.3.1.4" on draytek
.1.3.6.1.2.1.25.2.3.1.4.1 => [b'1024'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.4.3 => [b'1024'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.4.6 => [b'1024'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.4.7 => [b'1024'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.4.8 => [b'1024'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.4.10 => [b'1024'] 'INTEGER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.2.3.1.5" on draytek
.1.3.6.1.2.1.25.2.3.1.5.1 => [b'105896'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.5.3 => [b'105896'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.5.6 => [b'105896'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.5.7 => [b'24724'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.5.8 => [b'6260'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.5.10 => [b'0'] 'INTEGER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.2.3.1.6" on draytek
.1.3.6.1.2.1.25.2.3.1.6.1 => [b'97452'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.6.3 => [b'97452'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.6.6 => [b'5584'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.6.7 => [b'24724'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.6.8 => [b'6260'] 'INTEGER'
.1.3.6.1.2.1.25.2.3.1.6.10 => [b'0'] 'INTEGER'
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.1" on draytek
.1.3.6.1.2.1.2.2.1.1.1 => [b'1'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.2 => [b'2'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.3 => [b'3'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.4 => [b'4'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.5 => [b'5'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.6 => [b'6'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.7 => [b'7'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.8 => [b'8'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.10 => [b'10'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.11 => [b'11'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.12 => [b'12'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.13 => [b'13'] 'INTEGER32'
.1.3.6.1.2.1.2.2.1.1.17 => [b'17'] 'INTEGER32'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.2" on draytek
.1.3.6.1.2.1.2.2.1.2.1 => [b'lo'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.2 => [b'ip_vti0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.3 => [b'sit0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.4 => [b'ip6tnl0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.5 => [b'lan_int2_if'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.6 => [b'eth0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.7 => [b'eth0.1'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.8 => [b'eth0.2'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.10 => [b'br0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.11 => [b'wan_int2_if'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.12 => [b'ptm0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.13 => [b'ptm1'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.17 => [b'ptm0.7'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.3" on draytek
.1.3.6.1.2.1.2.2.1.3.1 => [b'24'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.2 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.3 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.4 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.5 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.6 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.7 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.8 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.10 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.11 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.12 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.13 => [b'6'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.17 => [b'6'] 'INTEGER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.5" on draytek
.1.3.6.1.2.1.2.2.1.5.1 => [b'10000000'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.3 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.4 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.5 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.6 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.7 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.8 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.10 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.11 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.12 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.13 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.17 => [b'0'] 'GAUGE'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.8" on draytek
.1.3.6.1.2.1.2.2.1.8.1 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.2 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.3 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.4 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.5 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.6 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.7 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.8 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.10 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.11 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.12 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.13 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.17 => [b'1'] 'INTEGER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.6" on draytek
.1.3.6.1.2.1.31.1.1.1.6.1 => [b'2212'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.6 => [b'2503288163'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.8 => [b'2503288163'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.10 => [b'121578314'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.12 => [b'1594460483'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.13 => [b'1594460483'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.17 => [b'5394924921'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.7" on draytek
.1.3.6.1.2.1.31.1.1.1.7.1 => [b'41'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.6 => [b'128814311'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.8 => [b'128814311'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.10 => [b'1651877'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.12 => [b'254654023'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.13 => [b'254654023'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.17 => [b'12120028'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.8" on draytek
.1.3.6.1.2.1.31.1.1.1.8.1 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.6 => [b'6'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.8 => [b'6'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.10 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.12 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.13 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.17 => [b'0'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.9" on draytek
.1.3.6.1.2.1.31.1.1.1.9.1 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.6 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.8 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.10 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.12 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.13 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.17 => [b'0'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.13" on draytek
.1.3.6.1.2.1.2.2.1.13.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.3 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.4 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.5 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.6 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.7 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.8 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.10 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.11 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.12 => [b'1436889'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.13 => [b'140'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.17 => [b'0'] 'COUNTER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.14" on draytek
.1.3.6.1.2.1.2.2.1.14.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.3 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.4 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.5 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.6 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.7 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.8 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.10 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.11 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.12 => [b'140'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.13 => [b'140'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.17 => [b'0'] 'COUNTER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.10" on draytek
.1.3.6.1.2.1.31.1.1.1.10.1 => [b'2212'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.6 => [b'878779374'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.8 => [b'878779374'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.10 => [b'390194436'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.12 => [b'1281004052'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.13 => [b'1281004052'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.17 => [b'4113733021'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.11" on draytek
.1.3.6.1.2.1.31.1.1.1.11.1 => [b'41'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.6 => [b'254872176'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.8 => [b'254872176'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.10 => [b'1655209'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.12 => [b'144140162'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.13 => [b'144140162'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.17 => [b'13909586'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.12" on draytek
.1.3.6.1.2.1.31.1.1.1.12.1 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.6 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.8 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.10 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.12 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.13 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.17 => [b'0'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.13" on draytek
.1.3.6.1.2.1.31.1.1.1.13.1 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.3 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.4 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.5 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.6 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.7 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.8 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.10 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.11 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.12 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.13 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.17 => [b'0'] 'COUNTER64'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.19" on draytek
.1.3.6.1.2.1.2.2.1.19.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.3 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.4 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.5 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.6 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.7 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.8 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.10 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.11 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.12 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.13 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.17 => [b'0'] 'COUNTER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.20" on draytek
.1.3.6.1.2.1.2.2.1.20.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.3 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.4 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.5 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.6 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.7 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.8 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.10 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.11 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.12 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.13 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.17 => [b'0'] 'COUNTER'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.21" on draytek
.1.3.6.1.2.1.2.2.1.21.1 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.3 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.4 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.5 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.6 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.7 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.8 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.10 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.11 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.12 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.13 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.21.17 => [b'0'] 'GAUGE'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.18" on draytek
.1.3.6.1.2.1.31.1.1.1.18.1 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.2 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.3 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.4 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.5 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.6 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.7 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.8 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.10 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.11 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.12 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.13 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.17 => [b''] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.2.2.1.6" on draytek
.1.3.6.1.2.1.2.2.1.6.1 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.2 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.3 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.4 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.5 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.6 => [b'\x14I\xbcX\x03\\'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.7 => [b'\x14I\xbcX\x03\\'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.8 => [b'\x14I\xbcX\x03\\'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.10 => [b'\x14I\xbcX\x03\\'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.11 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.12 => [b'\x14I\xbcX\x03]'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.13 => [b'\x00\xaa\xbb\x01#E'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.17 => [b'\x14I\xbcX\x03]'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.31.1.1.1.15" on draytek
.1.3.6.1.2.1.31.1.1.1.15.1 => [b'10'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.3 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.4 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.5 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.6 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.7 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.8 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.10 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.11 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.12 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.13 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.17 => [b'0'] 'GAUGE'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.1.1" on draytek
.1.3.6.1.2.1.1.1.0 => [b'DrayTek Corporation, Router Model: Vigor167, Version: 5.2.4, Build Date/Time: Thu Jan 18 11:23:14 CST 2024'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.1.2" on draytek
.1.3.6.1.2.1.1.2.0 => [b'.1.3.6.1.4.1.7367'] 'OBJECTID'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.1.4" on draytek
.1.3.6.1.2.1.1.4.0 => [b'https://www.draytek.com/about/contact-us'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.1.5" on draytek
.1.3.6.1.2.1.1.5.0 => [b'DrayTek'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.1.6" on draytek
.1.3.6.1.2.1.1.6.0 => [b'Germany'] 'OCTETSTR'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.1.3" on draytek
.1.3.6.1.2.1.1.3.0 => [b'144085769'] 'TICKS'
Executing BULKWALK (v2c) of ".1.3.6.1.2.1.25.1.1" on draytek
.1.3.6.1.2.1.25.1.1.0 => [b'144089253'] 'TICKS'
Write data to cache file /omd/sites/l22/tmp/check_mk/data_source_cache/snmp/checking/draytek
Trying to acquire lock on /omd/sites/l22/tmp/check_mk/data_source_cache/snmp/checking/draytek
Got lock on /omd/sites/l22/tmp/check_mk/data_source_cache/snmp/checking/draytek
Releasing lock on /omd/sites/l22/tmp/check_mk/data_source_cache/snmp/checking/draytek
Released lock on /omd/sites/l22/tmp/check_mk/data_source_cache/snmp/checking/draytek
[cpu_tracking] Stop [7f74617e0290 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.23999999836087227))]
 Source: SourceInfo(hostname='draytek', ipaddress='192.168.1.2', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f74617d1580]
Read from cache: NoCache(draytek, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'draytek'. Skip processing.
No piggyback files for '192.168.1.2'. Skip processing.
Get piggybacked data
[cpu_tracking] Stop [7f74617d1580 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f7461a30cb0]
+ PARSE FETCHER RESULTS
 HostKey(hostname='draytek', source_type=<SourceType.HOST: 1>)  -> Add sections: ['hr_cpu', 'hr_mem', 'if64', 'snmp_info', 'snmp_uptime']
 HostKey(hostname='draytek', source_type=<SourceType.HOST: 1>)  -> Add sections: []
Received no piggyback data
CPU utilization      Total CPU: 1.00%
Interface 06         [eth0], (up), MAC: 14:49:BC:58:03:5C, Speed: unknown, In: 20.5 kB/s, Out: 14.0 kB/s
Interface 07         [eth0.1], (up), MAC: 14:49:BC:58:03:5C, Speed: unknown, In: 0.00 B/s, Out: 0.00 B/s
Interface 08         [eth0.2], (up), MAC: 14:49:BC:58:03:5C, Speed: unknown, In: 20.5 kB/s, Out: 14.0 kB/s
Interface 10         [br0], (up), MAC: 14:49:BC:58:03:5C, Speed: unknown, In: 189 B/s, Out: 644 B/s
Interface 12         [ptm0], (up), MAC: 14:49:BC:58:03:5D, Speed: unknown, In: 13.7 kB/s, Out: 23.4 kB/s
Interface 17         [ptm0.7], (up), MAC: 14:49:BC:58:03:5D, Speed: unknown, In: 7.22 kB/s, Out: 6.12 kB/s
Memory               Total (RAM + Swap): 68.68% - 71.0 MiB of 103 MiB RAM, RAM: 68.68% - 71.0 MiB of 103 MiB
SNMP Info            DrayTek Corporation, Router Model: Vigor167, Version: 5.2.4, Build Date/Time: Thu Jan 18 11:23:14 CST 2024, DrayTek, Germany, https://www.draytek.com/about/contact-us
Uptime               Up since 2024-06-22 17:39:59, Uptime: 16 days 16 hours
[cpu_tracking] Stop [7f7461a30cb0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
value store: already loaded
value store: writing to disk
[snmp] Success, [piggyback] Success (but no data found for this host), execution time 0.2 sec | execution_time=0.240 user_time=0.030 system_time=0.010 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.210 cmk_time_agent=0.000
Thanks in advance!
Anyone? No ideas? ANy way to make CMK able to do the MIB?
The check that you want to use needs some rework / extension to work with your device.
Inside the linked issue the Vigor has only one ADSL interface/connection and the check expects more than one.
Iam not that familiar with python and CheckMK internals here.
However, Is there no possibility to let CMK do this on SNMP level with the provided MIB?
No - you need some type of check to fetch the OIDs and also build check results from these.
