404-error when accessing Web Gui
** CheckMK Enterprise Version 2.3.0p11.cee**
OS version: CentOS Stream 9
Error message: 404 Not Found - The requested URL was not found on this server
omd status shows everything runnung and green.
I have also ran this command, which has helped me before: omd update-apache-config site
Still nothing works. I had to reset my linux root password, after reboot this happend. I haven’t rebooted the machine for a while so I’m not sure if it happens because I changed the root password. I also tried updating from 2.2 to 2.3, same error happens on version 2.3.
Would appreciate any help or ideas, thanks!
quick update:
when I create a new site, same thing happens. So I guess it’s a problem with the apache running under my linux system. When I run " systemctl status httpd it says active (running)…
You should consider to check SELinux and Firewall setting. For testing purpose you can stop both and check if you able to access your checkmk site.
getenforce
setenforce 0
systemctl stop firewalld
If your access now is working you might would like to configure SELinux and the firewalld, have a look the docs for details:
