Anders
(Anders)
March 24, 2026, 9:15am
1
I’m trying to work with the new Metrics backend together with Prometheus scrapers (and OTel Ingest)
But I’d like to access the SQL Console for troubleshooting reasons as its somewhat cumbersome to use custom graphs.
The (german) docs shows a screenshot of the console but no way to access it. Tried port 26788 but didn’t work..
mschlenker
(Mattias Schlenker)
March 24, 2026, 9:31am
2
The port is bound to localhost. So, use the -L option of SSH to forward it to your local machine:
ssh -L 26788:localhost:26788 someuser@mycmkserver
Please note that the port is generated from the site name and thus changes between setups.
Anders
(Anders)
March 24, 2026, 11:31am
3
Thanks. I was thinking perhaps there would be some proxy going on in Apache just like a regular site.
I was looking at the conf files as well do bind to the host, but saw some settings for user permissions was bond to localhost so didn’t want to change any of that.
I did try curl first but it was not working
curl -vv http://localhost:26788
11:33:57.908609 [0-0] * Host localhost:26788 was resolved.
11:33:57.908661 [0-0] * IPv6: ::1
11:33:57.908687 [0-0] * IPv4: 127.0.0.1
11:33:57.908711 [0-0] * [SETUP] added
11:33:57.908754 [0-0] * Trying [::1]:26788...
11:33:57.908869 [0-0] * Connected to localhost (::1) port 26788
11:33:57.908893 [0-0] * using HTTP/1.x
11:33:57.908940 [0-0] > GET / HTTP/1.1
11:33:57.908940 [0-0] > Host: localhost:26788
11:33:57.908940 [0-0] > User-Agent: curl/8.12.1
11:33:57.908940 [0-0] > Accept: */*
11:33:57.909076 [0-0] * Request completely sent off
11:33:57.909360 [0-0] * Recv failure: Connection reset by peer
11:33:57.909384 [0-0] * closing connection #0
11:33:57.909404 [0-0] * [SETUP] close
11:33:57.909443 [0-0] * [SETUP] destroy
