Activate on selected sites : argument of type 'NoneType' is not iterable
Dear colleagues,
after updating to 2.1.0p9 I can’t activate changes. Have everybody a similar problem?
CMK version:
Checkmk Raw Edition 2.1.0p9
OS version:
Debian 9
2022-08-17 13:05:05,499 [40] [cmk.web 20297] http://checkmk.dhi-moskau.org/prod/check_mk/ajax_start_activation.py/prod/check_mk/ajax_start_activation.py Unhandled exception (Crash-ID: 11312612-1e14-11ed-8213-00505684c4a1)
File “/omd/sites/prod/lib/python3/cmk/gui/pages.py”, line 104, in handle_page
action_response = self.page()
File “/omd/sites/prod/lib/python3/cmk/gui/wato/pages/activate_changes.py”, line 673, in page
activation_id = manager.start(
File “/omd/sites/prod/lib/python3/cmk/gui/watolib/activate_changes.py”, line 633, in start
execute_activation_cleanup_background_job(maximum_age=60)
File “/omd/sites/prod/lib/python3/cmk/gui/watolib/activate_changes.py”, line 1325, in execute_activation_cleanup_background_job
if job.is_active():
File “/omd/sites/prod/lib/python3/cmk/gui/gui_background_job.py”, line 187, in is_active
return super().is_active()
File “/omd/sites/prod/lib/python3/cmk/gui/background_job.py”, line 381, in is_active
job_status = self.get_status()
File “/omd/sites/prod/lib/python3/cmk/gui/background_job.py”, line 473, in get_status
status = self._jobstatus.get_status_from_file()
File “/omd/sites/prod/lib/python3/cmk/gui/background_job.py”, line 597, in get_status_from_file
if “state” not in data:
TypeError: argument of type ‘NoneType’ is not iterable
Hi.
Please check if there is an error in configuration. You can do it with “cmk-update-config -v” to check the whole config. Did you implement a new check or extention package before?
Best regards,
Christian
Hello Christian,
cmk-update-config -v is done. Without result.
No
Do you have other ideas?
Thanks
Eugen
1/26 Rewriting password store…
2/26 Migrate Visuals context…
3/26 Update global settings…
4/26 Rewriting tags…
5/26 Rewriting hosts and folders…
6/26 Rewriting rulesets…
Replacing ruleset non_inline_snmp_hosts with snmp_backend_hosts
7/26 Rewriting discovered host labels…
8/26 Rewriting autochecks…
9/26 Cleanup version specific caches…
10/26 Migrating fs_used name…
11/26 Migrate pagetype topics…
12/26 Migrate dashlets…
13/26 Migrate LDAP connections…
14/26 Rewrite BI Configuration…
Skipping conversion of bi.mk (already done)
15/26 Set version specific user attributes…
16/26 Rewriting inventory data…
Skipping py2 inventory data update (already done)
17/26 Migrate audit log…
No audit log present. Skipping.
18/26 Sanitize audit log (Werk #13330)…
Skipping (already done)
19/26 Rename discovered host label files…
20/26 Rewriting host, service or contact groups…
21/26 Rewriting notification configuration for ServiceNow…
22/26 Renewing certificates without server name extension…
Skipping (nothing to do)
23/26 Adding site CA to trusted CAs…
24/26 Rewrite mknotifyd config for central site…
25/26 Rewriting InfluxDB connections…
26/26 Disabling unsafe EC rules…
i have the same Problem. Version 2.1.0p19.cre.
Activating a change displays this error
Hey Dirk, the solution was creating a new server and migrating all hosts manually. After 8 hours it was done)
oh, that’s sad… but if it is the only way
i have the same problem…
Any other soloutions without migrating everything to a new server?
Thank you.
Solved the issue with the update to 2.2.0p8
We are currently on Version 2.1.0p26 and had the same issue.
I edited the file /omd/sites/###/lib/python3/cmk/gui/background_job.py in class JobStatus to write out the job folders into a tmp file.
I found the folder/files in …/var/check_mk/background_jobs/activation_cleanup to be broken and deleted it.
After restarting the site everything was fine.
