how active checks can be debugged?
For example an http check is not working and shows this in the Service check command: check_mk_active-http!'-u' '/health-check' '--onredirect=follow' '--sni' '-p' '80' '$HOSTNAME$' 'www.foobar.com'
How can I manually run this command on the command line with debugging output?
all default active checks (i.e. checks that you haven’t placed there yourself) are in ~/lib/nagios/plugins
so in this case, the call you are looking for would be “check_http” and then all the parameters after the ! in the service_check_command
the $HOSTNAME$ would have to be resolved manually as it’s not a bash but a checkmk/nagios variable
If you catch yourself regularly needing to check active checks, I use the following script to make life easier:
#!/bin/bash
# very simple script to run a livestatus query against the livestatus socket of the local site
# returns: host_name service_description and the expanded (i.e. with resolved variables) check_command that will be run on the command line
# Script understands only 2 parameters, both regex
# ./get_command_expansion.sh [service_description_filter] <optional_host_name_filter>
if [ -z "$1" ] ; then
echo "Please provide part of a service_description so that we can filter somehow - if you want everything, use \".*\""
exit 1
fi
if [ -n "$2" ] ; then
hostfilter="Filter: host_name ~~ $2"
fi
query="GET services
Columns: host_name service_description check_command_expanded
Filter: service_description ~~ $1
$hostfilter"
echo -e "$query" | unixcat ${OMD_ROOT}/tmp/run/live
@gstolz oh thank you! Last time I was searching for the “onredirect” option I was not finding it. Didn’t see that is it just the scripts in the lib/nagios/plugins… Thought they are only used by “integrate Nagios plugins”. Thank you! Also for the script!
