I am new to this forum and to the use of this wonderful monitoring tool.
I would like to know if there is any possibility of increasing the timeout for Active Checkups (old Nagios type). I have a plugin that takes time to run (and doesn’t manage its own timeout) and checkmk shows right away that it failed to run.
The plugin (check_selenium_docker.py) with its arguments works correctly if you do it by command line.
Could it be that you’re looking for the rule “Service check timeout (Microcore)”?
With this, you should be able to change the timeouts of services, including active checks.
If you use this option “Paramters for this service”, you can always check which rule is working for this type of service:
In the corresponding site you should be able to find all matching rules with active rule-set and default values.
In the Raw version 1.6.0p8 there does not seem to be such an option “Service Verification Timeout (Microcore)”
In the Parameters for this service (Classical Active Check) i do not see if it is allowed to control the speed at which check is launched. I only see eligible options in the “Monitoring Configuration” section such as the:
Normal check interval for service checks
Retry check interval for service checks"
Maximun number of checks attepts for service, etc …"
