so as the topic says i got a custom check which i want to add to my monitoring. I bet its done with a few clicks, but i really cant find a way how to achieve this.
My second question is about adding an icon. With a specific command i can receive pdf reports from greenbone which i want to put in a download-icon or something similar.
Is this possible?
at work I also have a new project which involves greenbone/openvas.
The official scripts are to be found here:
Also, there seem to be some people who already implemented/used some sort of check:
I didn’t have the time to try either of them, since I am stuck with mobile device management for mac os x first, later we will scan those macintoshs with greenbone (shoot me pls ).
before i get into it, i want to add my custom check into the monitoring.
I see the custom check in the services of the specific host (like in my first picture above) but not in the monitoring. Where i can simply add the custom check?
You can find it under Host & Service Parameters -> Active Checks -> Classical active and passive Monitoring checks
Then just add a rule with the path to the gvm script followed by the parameters.
And under conditions enter the host where you want the service to be applied to (can also be any another condition and you can replace the hostname with the variable $HOSTNAME$ in the commandline arguments).
You should preferrably check the code and try to find out what is causing the error message to appear in the first place. The result of the check may be wrong to due this error appearing.
Alright. I got the script from greenbone, in Setup->Hosts-> Services of hosts it is displayed correctly. I don’t understand why the status in monitoring is not fully displayed
But i could not follow step 2 since i did not find the correct service customs icons..
I found it in my monitoring in my custom rule. There i could add a rule called Custom icons or actions..
