I wrote this patch to add the power difference verification against the first reading.
I think detecting this difference is perhaps more significant than setting a simple power threshold
I hope it can be integrated into one of the next releases.
--- share/check_mk/checks/cisco_temperature.orig 2020-06-10 10:44:26.000000000 +0200
+++ share/check_mk/checks/cisco_temperature 2020-06-10 10:49:55.636245186 +0200
@@ -344,6 +344,9 @@
discovery_cisco_dom_rules = []
+factory_settings['cisco_temperature_dom_default_levels'] = {
+ 'deviation_levels': (1.00, 2.00),
def inventory_cisco_temperature_dom(parsed):
@@ -357,7 +360,7 @@
dev_state = attrs.get('raw_dev_state')
adm_state = attrs.get('admin_state')
if dev_state == '1' and adm_state in admin_states_to_discover:
- yield item, {}
+ yield item, {"first_reading": attrs.get('reading')}
def _determine_levels(user_levels, device_levels):
@@ -398,10 +401,28 @@
dsname = "signal_power_dbm"
yield check_levels(reading, dsname, levels, unit='dBm', infoname="Signal power")
+ # Verify deviation from first reading
+ first_reading = params.get('first_reading')
+ if first_reading is not None:
+ deviation_levels_upper = params.get('deviation_levels') or (None, None)
+ # The deviation levels are absolute, but the difference can also be negative.
+ # Specular levels are created for negative deviations.
+ # 'human_readable_func = abs' is not used to have the graph with both positive and negative values.
+ if all(deviation_levels_upper):
+ deviation_levels_lower = tuple([x * -1 for x in deviation_levels_upper])
+ else:
+ deviation_levels_lower = (None,None)
+ levels = ( deviation_levels_upper + deviation_levels_lower )
+ deviation = reading - first_reading
+ dsname = "deviation_dbm"
+ yield check_levels(deviation, dsname, levels, unit='dBm', infoname="Deviation")
check_info['cisco_temperature.dom'] = {
"inventory_function": inventory_cisco_temperature_dom,
"check_function": check_cisco_temperature_dom,
+ "default_levels_variable" : "cisco_temperature_dom_default_levels",
"service_description": "DOM %s",
"group": "cisco_dom",
"has_perfdata": True,
--- lib/python/cmk/gui/plugins/metrics/check_mk.py.orig 2020-06-05 11:57:23.219924935 +0200
+++ lib/python/cmk/gui/plugins/metrics/check_mk.py 2020-06-19 14:27:45.010495963 +0200
@@ -1771,6 +1771,12 @@
"color": "#2080c0",
+metric_info["deviation_dbm"] = {
+ "title": _("Deviation"),
+ "unit": "dbm",
+ "color": "#b39eb5",
metric_info["signal_power_dbm"] = {
"title": _("Power"),
"unit": "dbm",
--- lib/python/cmk/gui/plugins/wato/check_parameters/cisco_dom.py.orig 2020-06-04 22:32:28.447985936 +0200
+++ lib/python/cmk/gui/plugins/wato/check_parameters/cisco_dom.py 2020-06-19 14:25:32.957293178 +0200
@@ -87,6 +87,26 @@
+def _vs_cisco_dom_deviation():
+ return (
+ "deviation_levels",
+ Alternative(
+ title="Levels for the deviation",
+ style="dropdown",
+ elements=[
+ Tuple(title=_("Use the following levels"),
+ elements=[
+ Float(title=_(u"Warnig at"), default_value=1.00, unit=_("dBm")),
+ Float(title=_(u"Critical at"), default_value=2.00, unit=_("dBm")),
+ FixedValue(
+ False,
+ title=_("No levels"),
+ totext="",
def _item_spec_cisco_dom():
return TextAscii(title=_("Sensor description if present, sensor index otherwise"))
@@ -95,6 +115,7 @@
return Dictionary(elements=[
(_vs_cisco_dom("upper")),
(_vs_cisco_dom("lower")),
+ (_vs_cisco_dom_deviation()),
