Add physical location to host and notification
Hi all,
Is there a way to add the physical location of a host to the hosts properties, and have that included on any e-mail notifications our administrators receive? We have about 50 locations, and all hosts are labelled by a site number, such as S14-DFCS01. When reading notification e-mails after-hours, looking up what site that is can be difficult.
Thanks!
This could be achieved by defining a custom host attribute under Setup → Hosts → Custom host attributes.
Example:
By selecting the last checkbox, the attribute can be used as a variable/macro in notifications.
Thanks for that. I was able to create a custom attribute for the location. I’ve been trying to figure out how to get the location included in our default notifications, any thoughts there?
In a notification script, the location should now be available in the environment variable $NOTIFY_HOST_LOCATION. At least with the CMC.
If you use the Nagios core, you need to edit the check-mk-notify command in ~/etc/nagios/conf.d/check_mk_templates.cfg. Insert a line like
NOTIFY_HOST_LOCATION='$_HOSTLOCATION$' \
in the variable definitions. After that change you need to restart Checkmk with cmk -R.
When using the predefined notification methods (e.g. HTML email or ASCII email), you can reference the custom attribute at some places. Example:
nice thread, searched something like this in the past.
tried it but doesn´t work. using raw edition, edit the check_mk_templates.cfg.
$_HOSTLOCATION$ resolved as CONTENT in notification mail…
Where comes the definition from, that $_HOSTLOCATION$ is the custom host attribute “Location”?
You need to dig a bit into Nagios configuration to track this.
When you edit a host object and enter a location in Checkmk, and activate your changes, Checkmk creates the file ~/etc/nagios/conf.d/check_mk_objects.cfg. Here, the content entered into the custom host attribute “location” is stored as _LOCATION within a host object. Example (shortened):
define host {
  _ADDRESS_4                    10.20.30.40
  _ADDRESS_FAMILY               4
  _FILENAME                     /wato/printer/hosts.mk
  _LOCATION                     My Office, 1st floor
  address                       10.20.30.40
  alias                         Brother MFC-L3750
  check_command                 check-mk-host-ping!-w 200.00,80.00% -c 500.00,100.00%
  host_name                     bromfc
  hostgroups                    printer
  use                           check_mk_host
The Nagios core makes the custom host attributes available as macros. From the Nagios documentation, chapter “Custom Variable Macros”:
Any custom object variables that you define in host, service, or contact definitions are also available as macros. Custom variable macros are named as follows:
  • $_HOSTvarname$
  • $_SERVICEvarname$
  • $_CONTACTvarname$
So in this case, the location information is available as macro _HOSTLOCATION.
That worked! Couldn’t figure out how to get it in the body of the e-mail, but I think it’s fine just as part of the subject. Good enough. Honestly, I’m really surprised this isn’t a built-in function by default when creating hosts.
