CMK version: 2.1.0p21.cre
OS version: Ubuntu 20.04
Hi everyone!
I have written a custom plugin to monitor temperatures via SNMP of a tcw122b temperature controller.
It works OK, and draws a graph.
However, I have hard-coded TEMP_CRIT
& TEMP_WARN
and I would like to set these parameters from the GUI (with WATO?).
First of all, I have tried looking around in the forum and on the internet for a solution but couldn’t find any… Maybe I just use poor keywords, so I don’t take any offense if someone just provides an all-solving URL.
I’ve read the documentation, and found out I had to look for a corresponding rule set (temperature
?), but adding
check_ruleset_name="temperature",
check_default_parameters={},
at the bottom of register.check_plugin()
, brings up the following error when running
cmk --detect-plugins=tcw122b_sensors_temp -vI tc1
Error in agent based plugin tcw122b_sensors_temp: check_function: 'params' argument expected if and only if default parameters are not None
I have trouble understanding this message as I can’t find the params
argument this error is talking about…
Anyways, I tried adding params
to my check_function
arguments like this
def check_tcw122b_sensors_temp(params, section)
But I get another error:
Error in agent based plugin tcw122b_sensors_temp: Check ruleset temperature has checks with and without item! At least one of the checks in this group needs to be changed (offending plugin: tcw122b_sensors_temp)
I have tried adding also an item
parameter but with no luck:
Error in agent based plugin tcw122b_sensors_temp: check_function: unexpected 'item' argument
I am stuck on this issue for several days now, I would be very happy if someone can point me in the right direction…
Here is the working version of the plugin
#!/usr/bin/env python3
# from official docs https://docs.checkmk.com/latest/en/devel_check_plugins.html#snmp
# Hard-coded parameters -> to be replaced by WATO
TEMP_CRIT = 50
TEMP_WARN = 35
def discover_tcw122b_sensors_temp(section):
yield Service()
def check_tcw122b_sensors_temp(section):
max_temp = 0
for temp in section:
if temp > max_temp:
max_temp = temp
if max_temp > TEMP_CRIT:
state = State.CRIT
elif (max_temp > TEMP_WARN):
state = State.WARN
else:
state = State.OK
yield Metric("Temperature", value=max_temp, levels=(TEMP_WARN, TEMP_CRIT), boundaries=(0, 100))
yield Result(state=state, summary="Temperature: {}°C".format(max_temp))
return
def parse_tcw122b_sensors_temp(string_table):
parsed = []
for temp in string_table:
# Turn temperature from 10*C° to C°
parsed.append(int(temp[0])/10)
return parsed
# SNMP section
register.snmp_section(
name = 'tcw122b_sensors_temp',
detect = startswith('.1.3.6.1.2.1.1.1.0', 'TCW122B'),
parse_function = parse_tcw122b_sensors_temp,
fetch = SNMPTree(
base = '.1.3.6.1.4.1.38783.3',
oids = [
'9', # temp1x10Int
#'10', # temp2x10Int
#'11', # humi1x10Int
#'12', # humi2x10Int
service_name = 'TCW122B Temperature',
discovery_function = discover_tcw122b_sensors_temp,
check_function = check_tcw122b_sensors_temp,
