I am creating a custom plugins for an SNMP card which monitors our HVAC. After doing the following commands, there was no error on CLI however in CHeckmk dashboard it shows UNKNOWN state. Can anyone help me on this issue?
- cmk --detect-plugins=hvac_C2 -vl hvac-2
- cmk --debug -II --detect-plugins=hvac_C2 -vl hvac-2
- cmk -vv --debug --detect-plugins=hvac_C2 hvac-2
These are the code
import re
from cmk.base.plugins.agent_based.agent_based_api.v1 import (
get_value_store,
def discover_hvac_C2(section):
yield Service()
def check_hvac_C2(section):
hvac_snmp_C2 = int(section[0][0])
##Compressor 1
if hvac_snmp_C2 == 0:
hvac_snmp_value_converted = "Off"
summary_hvac_C2 = "Compressor2 Status: " + str(hvac_snmp_value_converted)
#yield Result(state=State.OK,summary=summary_hvac_C2)
else:
hvac_snmp_value_converted = "On"
#yield Result(state=State.CRIT,summary=summary_hvac_C2)
hvac_snmp_C2_name = "Compressor_Status"
yield Metric(hvac_snmp_C2_name,hvac_snmp_C2)
register.snmp_section(
name = "hvac_C2",
#detect = contains(".1.3.6.1.2.1.1.1.0","licheepi-zero"),
detect = exists(".1.3.6.1.4.1.7416.1.2.30019.0"),
fetch = SNMPTree(
base = '.1.3.6.1.4.1.7416.1.2',
oids = ['31.0'],
##register plugins
register.check_plugin(
name = "hvac_C2",
sections = ["hvac_C2"],
service_name='HVAC Compressor 2',
discovery_function= discover_hvac_C2,
check_function= check_hvac_C2,
Result from * cmk -vv --debug --detect-plugins=hvac_C2 hvac-2
OMD[cmkvm]:~/local/share/check_mk/checks$ cmk --detect-plugins=hvac_C2 -vl hvac-2
Discovering services and host labels on: hvac-2
hvac-2:
+ FETCHING DATA
No piggyback files for 'hvac-2'. Skip processing.
No piggyback files for '10.224.1.35'. Skip processing.
+ ANALYSE DISCOVERED HOST LABELS
SUCCESS - Found no host labels
+ ANALYSE DISCOVERED SERVICES
+ EXECUTING DISCOVERY PLUGINS (1)
1 hvac_C2
SUCCESS - Found 1 services
OMD[cmkvm]:~/local/share/check_mk/checks$ cmk -vv --debug --detect-plugins=hvac_C2 hvac-2
Checkmk version 2.1.0p2
Trying to acquire lock on /omd/sites/cmkvm/var/check_mk/license_usage/next_run
Got lock on /omd/sites/cmkvm/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/cmkvm/var/check_mk/license_usage/history.json
Got lock on /omd/sites/cmkvm/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cmkvm/var/check_mk/license_usage/history.json
Released lock on /omd/sites/cmkvm/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/cmkvm/var/check_mk/license_usage/next_run
Released lock on /omd/sites/cmkvm/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7f202da369d0]
[SNMPFetcher] Fetch with cache settings: SNMPFileCache(hvac-2, base_path=/omd/sites/cmkvm/tmp/check_mk/data_source_cache/snmp, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Mode Mode.FORCE_SECTIONS)
hvac_C2: Fetching data (SNMP walk cache cleared)
Executing BULKWALK of ".1.3.6.1.4.1.7416.1.2.31" on hvac-2
.1.3.6.1.4.1.7416.1.2.31.0 => [b'0'] 'INTEGER'
[cpu_tracking] Stop [7f202da369d0 - Snapshot(process=posix.times_result(user=0.08999999999999986, system=0.020000000000000018, children_user=0.0, children_system=0.0, elapsed=0.15000000223517418))]
[cpu_tracking] Start [7f202da0b850]
[PiggybackFetcher] Fetch with cache settings: NoCache(hvac-2, base_path=/omd/sites/cmkvm/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
[cpu_tracking] Stop [7f202da0b850 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
+ PARSE FETCHER RESULTS
No persisted sections
-> Add sections: ['hvac_C2']
-> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f202da0b640]
value store: synchronizing
Trying to acquire lock on /omd/sites/cmkvm/tmp/check_mk/counters/hvac-2
Got lock on /omd/sites/cmkvm/tmp/check_mk/counters/hvac-2
Releasing lock on /omd/sites/cmkvm/tmp/check_mk/counters/hvac-2
Released lock on /omd/sites/cmkvm/tmp/check_mk/counters/hvac-2
value store: already loaded
[cpu_tracking] Stop [7f202da0b640 - Snapshot(process=posix.times_result(user=0.0, system=0.010000000000000009, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[snmp] Success, execution time 0.2 sec | execution_time=0.180 user_time=0.090 system_time=0.040 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.040 cmk_time_agent=0.000
+ FETCHING DATA
[cpu_tracking] Start [7f3a044e2d60]
[cpu_tracking] Stop [7f3a044e2d60 - Snapshot(process=posix.times_result(user=0.0, system=0.08000000000000007, children_user=0.0, children_system=0.0, elapsed=0.12000000104308128))]
[cpu_tracking] Start [7f3a043e4490]
[cpu_tracking] Stop [7f3a043e4490 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
-> Add sections: []
[cpu_tracking] Start [7f3a043e45b0]
HVAC Compressor 2 Compressor2 Status: Off
[cpu_tracking] Stop [7f3a043e45b0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[snmp] Success, execution time 0.1 sec | execution_time=0.130 user_time=0.000 system_time=0.080 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.040 cmk_time_agent=0.000
