Hi there,
any help is appreciated
CMK version: 2.2.0p5.cre
OS version: Debian GNU/Linux 10 (buster)
Error message: An error occurred: Error creating configuration: too many values to unpack (expected 2)
Output of “cmk --debug -vvR”:
Trying to acquire lock on /omd/sites/sitename/etc/check_mk/main.mk
Got lock on /omd/sites/sitename/etc/check_mk/main.mk
Generating configuration for core (type nagios)...
Trying to acquire lock on /omd/sites/sitename/var/check_mk/core/helper_config/serial.mk
Got lock on /omd/sites/sitename/var/check_mk/core/helper_config/serial.mk
Releasing lock on /omd/sites/sitename/var/check_mk/core/helper_config/serial.mk
Released lock on /omd/sites/sitename/var/check_mk/core/helper_config/serial.mk
Trying to acquire lock on /omd/sites/sitename/var/check_mk/licensing/licensed_state
Got lock on /omd/sites/sitename/var/check_mk/licensing/licensed_state
Releasing lock on /omd/sites/sitename/var/check_mk/licensing/licensed_state
Released lock on /omd/sites/sitename/var/check_mk/licensing/licensed_state
Releasing lock on /omd/sites/sitename/etc/check_mk/main.mk
Released lock on /omd/sites/sitename/etc/check_mk/main.mk
Trying to acquire lock on /omd/sites/sitename/var/check_mk/crashes/base/0c0f28ce-1c19-11ee-aad2-c6549e47524c/crash.info
Got lock on /omd/sites/sitename/var/check_mk/crashes/base/0c0f28ce-1c19-11ee-aad2-c6549e47524c/crash.info
Releasing lock on /omd/sites/sitename/var/check_mk/crashes/base/0c0f28ce-1c19-11ee-aad2-c6549e47524c/crash.info
Released lock on /omd/sites/sitename/var/check_mk/crashes/base/0c0f28ce-1c19-11ee-aad2-c6549e47524c/crash.info
File "/omd/sites/sitename/bin/cmk", line 112, in <module>
File "/omd/sites/sitename/lib/python3/cmk/base/modes/__init__.py", line 68, in call
return handler(*handler_args)
File "/omd/sites/sitename/lib/python3/cmk/base/modes/check_mk.py", line 1259, in mode_restart
cmk.base.core.do_restart(
File "/omd/sites/sitename/lib/python3/cmk/base/core.py", line 81, in do_restart
core_config.do_create_config(
File "/omd/sites/sitename/lib/python3/cmk/base/core_config.py", line 271, in do_create_config
_create_core_config(
File "/omd/sites/sitename/lib/python3/cmk/base/core_config.py", line 356, in _create_core_config
core.create_config(config_path, config_cache, hosts_to_update=hosts_to_update)
File "/omd/sites/sitename/lib/python3/cmk/base/core_config.py", line 79, in create_config
self._create_config(config_path, config_cache, licensing_handler, hosts_to_update)
File "/omd/sites/sitename/lib/python3/cmk/base/core_nagios.py", line 88, in _create_config
self._create_core_config(config_path, licensing_handler)
File "/omd/sites/sitename/lib/python3/cmk/base/core_nagios.py", line 106, in _create_core_config
create_config(
File "/omd/sites/sitename/lib/python3/cmk/base/core_nagios.py", line 198, in create_config
all_host_labels[hostname] = _create_nagios_config_host(
File "/omd/sites/sitename/lib/python3/cmk/base/core_nagios.py", line 246, in _create_nagios_config_host
service_labels=_create_nagios_servicedefs(
File "/omd/sites/sitename/lib/python3/cmk/base/core_nagios.py", line 491, in _create_nagios_servicedefs
for description, args in core_config.iter_active_check_services(
File "/omd/sites/sitename/lib/python3/cmk/base/core_config.py", line 476, in iter_active_check_services
active_info["argument_function"](params),
File "/omd/sites/sitename/share/check_mk/checks/check_http", line 263, in check_http_arguments
host = _host_from_params(params.get("host", {}))
File "/omd/sites/sitename/share/check_mk/checks/check_http", line 113, in _host_from_params
address_type, address = address_settings
ValueError: too many values to unpack (expected 2)
