After upgrade from 2.0.0p9 to 2.2.0p14: "Error creating configuration: MAC check failed"
I updated checkmk raw docker from
  • 2.0.0p9
to 2.2.0p14 with the update steps:
  • 2.0.0p39
  • 2.1.0p37
Web UI is working fine. But if i Want to apply some configuration. I get th error:
An error occurred: Error creating configuration: MAC check failed
This seems a known fixed issue: Werk #13641: Fix ‘ValueError: MAC check failed’ error in “Rewriting rulesets” phase of update
but it seems i dont need to do anything?
Compatibility	Compatible - no manual interaction needed
Not sure how to proceed.
I could trigger the error message under “Setup > General > Passwords”. So i digged further and found the file:
cmk/var/check_mk/stored_passwords
This file was in cleartext and on my dummy fresh instance in binary. So i renamed the file and it got recreated with the content and the error message with MAC dissapeared. :slight_smile:
