Is it possible that you have a rule “Installation paths for agent files (Linux, UNIX)” in your system? If yes please check this rule. On my test system it is working without this error.
Hi @andreas-doehler
yes, we have such a rule for “Directory for storage of temporary data” that we set to “/var/tmp/” because our “/tmp” has no-exec bit enabled.
This was working in p11
that was the right hint. When setting all other folders with default value also the bakery works.
Thank you.
But i think this should be considered as a bug.
The problem had been found and fixed, the fix had been sent for the review.
Next release will be fre from the bug. In meantime, I would suggest to use the workaround from Andreas Doehler.
Thank you, guys, for very useful information.
