Version: CEE 2.2.0p7
OS: Debian Linux 11.7
Error message: [agent] Communication failed: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:2546)
Hi all,
we recently updated our distributed monitoring from 2.0.0p37 via latest 2.1.0 and 2.2.0p5, to 2.2.0p7.
I built new agents using the agent bakery, deployed them and enabled the TLS connection between all slaves and the master successfully.
Now I tried to change the agent communication for several of our monitored hosts (Linux and Windows). It was always the same behavior for Linux and Windows clients. The registration against the corresponding slaves works fine and I can see with cmk-agent-ctl status, that the host is registered and in pull-mode now:
But the monitoring is not able to query the host anymore:
I reinstalled the agent manually and re-registered it multiple times, but nothing helped.
From the log in C:\ProgramData\checkmk\agent\log\check_mk.log:
2023-07-31 18:00:32.394 [ctl:4016] [cmk_agent_ctl::modes::pull][INFO] [::ffff:10.*.*.*]:48286: Handling pull request.
2023-07-31 18:00:32.418 [ctl:4016] [cmk_agent_ctl::modes::pull][DEBUG] [::ffff:10.*.*.*]:48286: Handling pull request DONE (Task detached).
2023-07-31 18:00:32.449 [ctl:4016] [cmk_agent_ctl::modes::pull][DEBUG] handle_request starts
2023-07-31 18:00:32.488 [srv 7448] Request is '::ffff:10.*.*.* Global\WinAgentCtl_4016_3324_0'
2023-07-31 18:00:32.515 [srv 7448] [Warn ] OHM file 'C:\ProgramData\checkmk\agent\bin\OpenHardwareMonitorCLI.exe' is not found
2023-07-31 18:00:32.517 [ctl:4016] [rustls::server::hs][DEBUG] decided upon suite TLS13_AES_256_GCM_SHA384
2023-07-31 18:00:32.543 [ctl:4016] [rustls::conn][WARN] Sending fatal alert HandshakeFailure
2023-07-31 18:00:36.731 [ctl:4016] [rustls::server::hs][DEBUG] decided upon suite TLS13_AES_256_GCM_SHA384
2023-07-31 18:00:42.059 [ctl:4016] [cmk_agent_ctl::modes::pull][DEBUG] processed task!
Then I tried to register the host to a second CMK site (teststg1), which is running on the same VM as the first site “stg1”. This instance was a copy of “stg1”, where we tested the upgrade steps, before we upgraded our PROD system). That worked also fine. So the host “pathfinder” is now registered to two different sites:
Now the fun part, I try to query from both sites (left: site stg1; right: site teststg1):
So the query works fine for the site “teststg1”, but fails for site “stg1” with the TLS handshake error.
Full output of Output of “cmk --debug -vvn pathfinder”: on site “stg1”:
OMD[stg1]:~$ cmk --debug -vvn pathfinder
Checkmk version 2.2.0p7
+ FETCHING DATA
Source: SourceInfo(hostname='pathfinder', ipaddress='10.*.*.*', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f39f7571b90]
Read from cache: AgentFileCache(pathfinder, path_template=/omd/sites/stg1/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (does not exist)
Connecting via TCP to 10.*.*.*:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Closing TCP connection to 10.*.*.*:6556
[cpu_tracking] Stop [7f39f7571b90 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
Source: SourceInfo(hostname='pathfinder', ipaddress='10.*.*.*', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f39f6601ed0]
Read from cache: NoCache(pathfinder, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
Piggyback file '/omd/sites/stg1/tmp/check_mk/piggyback/pathfinder/HSTG26': Successfully processed from source 'HSTG26'
No piggyback files for '10.*.*.*'. Skip processing.
[cpu_tracking] Stop [7f39f6601ed0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<hyperv_vmstatus:cached(1690820202,90)>>> / Transition NOOPParser -> HostSectionParser
<<<hyperv_checkpoints:cached(1690820202,90)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
HostKey(hostname='pathfinder', source_type=<SourceType.HOST: 1>) -> Not adding sections: SSLError(1, '[SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:2546)')
HostKey(hostname='pathfinder', source_type=<SourceType.HOST: 1>) -> Add sections: ['hyperv_checkpoints', 'hyperv_vmstatus', 'labels']
Received no piggyback data
[cpu_tracking] Start [7f39f620fb90]
value store: synchronizing
Trying to acquire lock on /omd/sites/stg1/tmp/check_mk/counters/pathfinder
Got lock on /omd/sites/stg1/tmp/check_mk/counters/pathfinder
Releasing lock on /omd/sites/stg1/tmp/check_mk/counters/pathfinder
Released lock on /omd/sites/stg1/tmp/check_mk/counters/pathfinder
CPU utilization PEND Check plugin received no monitoring data
Check_MK Agent PEND Check plugin received no monitoring data
Disk IO SUMMARY PEND Check plugin received no monitoring data
HyperV Checkpoints No Checkpoints found
HyperV Status Integration Service State: Ok
Interface Microsoft Hyper-V Network Adapter PEND Check plugin received no monitoring data
LOG Application PEND Check plugin received no monitoring data
LOG System PEND Check plugin received no monitoring data
Memory and pagefile PEND Check plugin received no monitoring data
Processor Queue PEND Check plugin received no monitoring data
Service Summary PEND Check plugin received no monitoring data
Sessions PEND Check plugin received no monitoring data
System Time PEND Check plugin received no monitoring data
TCP Connections PEND Check plugin received no monitoring data
Uptime PEND Check plugin received no monitoring data
Windows License PEND Check plugin received no monitoring data
fs_C:/ PEND Check plugin received no monitoring data
service_Netlogon PEND Check plugin received no monitoring data
service_TermService PEND Check plugin received no monitoring data
service_WinRM PEND Check plugin received no monitoring data
[cpu_tracking] Stop [7f39f620fb90 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.010000001639127731))]
[agent] SSLError(1, '[SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:2546)')(!!), [piggyback] Successfully processed from source 'HSTG26', Missing monitoring data for plugins: checkmk_agent, df, logwatch, mem_win, services, services_summary, systemtime, tcp_conn_stats, uptime, win_license, winperf_if, winperf_phydisk, winperf_processor_util, winperf_ts_sessions, wmi_cpuload(!), execution time 0.0 sec | execution_time=0.030 user_time=0.020 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.010
Full output of Output of “cmk --debug -vvn pathfinder”: on site “teststg1”:
OMD[teststg1]:~$ cmk --debug -vvn pathfinder
+ FETCHING DATA
[cpu_tracking] Start [7f995e226190]
Read from cache: AgentFileCache(pathfinder, path_template=/omd/sites/teststg1/tmp/check_mk/cache/{hostname}, max_age=MaxAge(checking=0, discovery=120, inventory=120), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 49 sec, allowed is 0 sec)
Write data to cache file /omd/sites/teststg1/tmp/check_mk/cache/pathfinder
Trying to acquire lock on /omd/sites/teststg1/tmp/check_mk/cache/pathfinder
Got lock on /omd/sites/teststg1/tmp/check_mk/cache/pathfinder
Releasing lock on /omd/sites/teststg1/tmp/check_mk/cache/pathfinder
Released lock on /omd/sites/teststg1/tmp/check_mk/cache/pathfinder
[cpu_tracking] Stop [7f995e226190 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=5.300000000745058))]
[cpu_tracking] Start [7f995c70ddd0]
No piggyback files for 'pathfinder'. Skip processing.
[cpu_tracking] Stop [7f995c70ddd0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
<<<wmi_cpuload:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<df:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<fileinfo:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<services>>> / Transition HostSectionParser -> HostSectionParser
<<<logwatch>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_phydisk>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_if>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_processor>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_tcp_conn>>> / Transition HostSectionParser -> HostSectionParser
<<<winperf_ts_sessions>>> / Transition HostSectionParser -> HostSectionParser
<<<checkmk_agent_plugins_win:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<dotnet_clrmemory:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<ps:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
Transition HostSectionParser -> NOOPParser
<<<winperf_if_teaming:sep(9)>>> / Transition NOOPParser -> HostSectionParser
<<<winperf_if_get_netadapter:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<win_license>>> / Transition HostSectionParser -> HostSectionParser
<<<cmk_update_agent_status:cached(1690816779,3600):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<win_netstat>>> / Transition HostSectionParser -> HostSectionParser
<<<systemtime>>> / Transition NOOPParser -> HostSectionParser
HostKey(hostname='pathfinder', source_type=<SourceType.HOST: 1>) -> Add sections: ['check_mk', 'checkmk_agent_plugins_win', 'cmk_agent_ctl_status', 'cmk_update_agent_status', 'df', 'dotnet_clrmemory', 'fileinfo', 'logwatch', 'mem', 'ps', 'services', 'systemtime', 'uptime', 'win_license', 'win_netstat', 'winperf_if', 'winperf_if_get_netadapter', 'winperf_if_teaming', 'winperf_phydisk', 'winperf_processor', 'winperf_tcp_conn', 'winperf_ts_sessions', 'wmi_cpuload']
HostKey(hostname='pathfinder', source_type=<SourceType.HOST: 1>) -> Add sections: []
[cpu_tracking] Start [7f995c74fed0]
Trying to acquire lock on /omd/sites/teststg1/tmp/check_mk/counters/pathfinder
Got lock on /omd/sites/teststg1/tmp/check_mk/counters/pathfinder
Releasing lock on /omd/sites/teststg1/tmp/check_mk/counters/pathfinder
Released lock on /omd/sites/teststg1/tmp/check_mk/counters/pathfinder
CPU utilization Total CPU: 84.52%
Check_MK Agent Version: 2.2.0p7, OS: windows, Update error: The agent updater is not registered at the deployment server(!), No successful connect to server yet(!), Agent plugins: 5, Local checks: 0
Disk IO SUMMARY Read: 164 kB/s, Write: 1.13 MB/s, Latency: 6 milliseconds
Interface Microsoft Hyper-V Network Adapter [Ethernet], (Up), MAC: 00:15:5D:08:E2:08, Speed: 2 GBit/s, In: 892 kBit/s (0.04%), Out: 3.25 MBit/s (0.16%)
LOG Application No error messages
LOG System No error messages
Memory and pagefile RAM: 84.32% - 3.37 GiB of 4.00 GiB, 2 min average: 84.16% (3.37 GiB), Commit charge: 76.18% - 3.62 GiB of 4.75 GiB, 2 min average: 75.56% (3.59 GiB)
Processor Queue 15 min load: 2.92, 15 min load per core: 1.46 (2 logical cores)
Service Summary Autostart services: 60, Stopped services: 4
Sessions 1 Active, 2 Inactive
System Time Offset: -38 milliseconds
TCP Connections Established: 7
Uptime Up since Jul 14 2023 14:22:39, Uptime: 17 days 3 hours
Windows License Software is Licensed, License will expire in 174 days 19 hours
fs_C:/ Used: 59.97% - 47.1 GiB of 78.6 GiB, trend per 1 day 0 hours: +288 MiB, trend per 1 day 0 hours: +0.36%, Time left until disk full: 111 days 19 hours
service_Netlogon Netlogon: running (start type is auto)
service_TermService Remote Desktop Services: running (start type is demand)
service_WinRM Windows Remote Management (WS-Management): running (start type is auto)
[cpu_tracking] Stop [7f995c74fed0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
[agent] Success, [piggyback] Success (but no data found for this host), execution time 5.3 sec | execution_time=5.320 user_time=0.010 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=5.300
To sum up: Two almost identical sites on one VM and one site can query a registered host with TLS, while the second site fails with a TLS handshake error.
Any ideas and clues are more than welcome!
Cheers Manuel
