[agent]: Communication failed: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:2546)
Hi.
I get this error [agent]: Communication failed: [SSL: SSLV3_ALERT_HANDSHAKE_FAILURE] sslv3 alert handshake failure (_ssl.c:2546) but just on some servers. I’ve tried everything… uninstalling and reinstalling the agent, troubleshooting and so on… all I could find was this:
Request failed. (invalid peer certificate contents: invalid peer certificate: UnknownIssuer)
[rustls::conn] Sending fatal alert HandshakeFailure
ss -tulpn |grep 6556
tcp LISTEN 0 4096 *:6556 : users:((“cmk-agent-ctl”,pid=1474638,fd=9))
CMK version:
Version: 2.2.0p12
OS version:
Debian GNU/Linux 12 (bookworm)
Hi.
Did you try to remove the TLS certificate for the agent encryption from the given host?
There is a button in the host menu when you edit the host. Did you also try to rum the agent communication in legacy mode?
RG, Christian
Hi, thank you for advice. Removing TLS certificate didn’t work, but running agent communication in legacy mode, fixed my issue. Unfortunately I could not find why it was not possible to arrange the agent to work via cmk-agent-ctl or via TLS on Debian GNU/Linux 12 (bookworm)
