Agent_proxmox_ve breaks checkmk 2.5.0 when no subscription is present
CMK version: 2.5.0
OS version: Debian 13
Error message: Failed: ‘status’ - please submit a crash report! (Crash-ID: eb682010-4322-11f1-8000-bc2411a8ad4d)(!!)
Checkmk version 2.5.0
+ FETCHING DATA
  Source: SourceInfo(hostname='<HOSTNAME>', ipaddress='<HOSTIP>', ident='agent', fetcher_type=<FetcherType.TCP: 8>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f58c2b5cec0]
Read from cache: AgentFileCache(base_path=/omd/sites/monitoring, relative_path_template=tmp/check_mk/cache/<HOSTNAME>, max_age=MaxAge(checking=90, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Using data from cache file /omd/sites/monitoring/tmp/check_mk/cache/<HOSTNAME>
Got 213398 bytes data from cache
[cpu_tracking] Stop [7f58c2b5cec0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
  Source: SourceInfo(hostname='<HOSTNAME>', ipaddress='<HOSTIP>', ident='special_proxmox_ve', fetcher_type=<FetcherType.SPECIAL_AGENT: 6>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f58c307a0d0]
Read from cache: AgentFileCache(base_path=/omd/sites/monitoring, relative_path_template=tmp/check_mk/data_source_cache/special_proxmox_ve/<HOSTNAME>, max_age=MaxAge(checking=90, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (does not exist)
Calling: /omd/sites/monitoring/lib/python3.13/site-packages/cmk/plugins/proxmox_ve/libexec/agent_proxmox_ve -u checkmk@pve --password-id uuid70157560-f509-4f36-a7b3-bcde8aa1038e:/omd/sites/monitoring/var/check_mk/passwords_merged --no-cert-check <HOSTIP>
Get data from program
[cpu_tracking] Stop [7f58c307a0d0 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.4, children_system=0.04, elapsed=20.86999999731779))]
  Source: SourceInfo(hostname='<HOSTNAME>', ipaddress='<HOSTIP>', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f58c2d287d0]
Read from cache: NoCache(base_path=/dev/null, relative_path_template=, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
[cpu_tracking] Stop [7f58c2d287d0 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
[cpu_tracking] Start [7f58c2c51220]
+ PARSE FETCHER RESULTS
<<<zfsget:sep(9)>>> / Transition HostSectionParser -> HostSectionParser
<<<zfsget>>> / Transition HostSectionParser -> HostSectionParser
<<<nfsmounts_v2:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
<<<lnx_bonding:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<corosync_latency>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq>>> / Transition HostSectionParser -> HostSectionParser
<<<postfix_mailq_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<zpool_status>>> / Transition HostSectionParser -> HostSectionParser
<<<zpool>>> / Transition HostSectionParser -> HostSectionParser
<<<lnx_thermal:sep(124)>>> / Transition HostSectionParser -> HostSectionParser
<<<pvecm_status:sep(58)>>> / Transition HostSectionParser -> HostSectionParser
<<<pvecm_nodes>>> / Transition HostSectionParser -> HostSectionParser
<<<chrony:cached(1777402335,120)>>> / Transition HostSectionParser -> HostSectionParser
<<<cmk_update_agent_status:sep(0)>>> / Transition HostSectionParser -> HostSectionParser
Get piggybacked data
0 piggyback files for '<HOSTNAME>'.
0 piggyback files for '<HOSTIP>'.
  HostKey(hostname='<HOSTNAME>', source_type=<SourceType.HOST: 1>)  -> Add sections: ['check_mk', 'checkmk_agent_plugins_lnx', 'chrony', 'cifsmounts', 'cmk_agent_ctl_status', 'cmk_update_agent_status', 'corosync_latency', 'cpu', 'df_v2', 'diskstat', 'job', 'kernel', 'labels', 'lnx_bonding', 'lnx_if', 'lnx_thermal', 'local', 'md', 'mem', 'mounts', 'nfsmounts_v2', 'postfix_mailq', 'postfix_mailq_status', 'ps_lnx', 'pvecm_nodes', 'pvecm_status', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest', 'zfsget', 'zpool', 'zpool_status']
  HostKey(hostname='<HOSTNAME>', source_type=<SourceType.HOST: 1>)  -> Add sections: []
Received no piggyback data
[cpu_tracking] Stop [7f58c2c51220 - Snapshot(process=posix.times_result(user=0.1100000000000001, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.10999999940395355))]
[agent] Success, [special_proxmox_ve] Failed: 'status' - please submit a crash report! (Crash-ID: eb682010-4322-11f1-8000-bc2411a8ad4d)(!!), [piggyback] Success (but no data found for this host), execution time 21.0 sec | execution_time=20.980 user_time=0.120 system_time=0.000 children_user_time=0.400 children_system_time=0.040 cmk_time_agent=0.000 cmk_time_ds=20.420
Agent exited with code 1: /omd/sites/monitoring/lib/python3.13/site-packages/urllib3/connectionpool.py:1097: InsecureRequestWarning: Unverified HTTPS request is being made to host '<HOSTIP>'. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.io/en/latest/advanced-usage.html#tls-warnings
  File "/omd/sites/monitoring/lib/python3.13/site-packages/cmk/server_side_programs/v1_unstable/_crash_reporting.py", line 96, in wrapper
    return func(*args, **kwargs)
  File "/omd/sites/monitoring/lib/python3.13/site-packages/cmk/plugins/proxmox_ve/special_agent/agent_proxmox_ve.py", line 531, in main
    return agent_proxmox_ve_main(parse_arguments(sys.argv[1:]))
  File "/omd/sites/monitoring/lib/python3.13/site-packages/cmk/plugins/proxmox_ve/special_agent/agent_proxmox_ve.py", line 328, in agent_proxmox_ve_main
    for name, content in _create_node_sections(
        node,
    ...<6 lines>...
        data,
  File "/omd/sites/monitoring/lib/python3.13/site-packages/cmk/plugins/proxmox_ve/special_agent/agent_proxmox_ve.py", line 378, in _create_node_sections
    status=node["subscription"]["status"],
KeyError: 'status'
It appears the issue is that the API data does not contain subscription info (which was fine in 2.4.x).
Typical special agent programming bug - don’t expect the data to be there also if you think the data should be there :rofl:
If this code would be the same as in the old agent you would have no problem.
@martin.hirschvogel some more work to do
Works on my Proxmox monitoring :wink:
thanks, will forward!
We are working on it. Should be fixed in 2.5.0p1
As Martin said, he already created an internal ticket for this and we will fix this.
There is just one thing I am wondering about: Which version of Proxmox are you using @pep ?
That would be 9.1.9.
same issue with Proxmox 8.4.18
Hello everyone! Sorry for the inconvenience. The issue will be fixed with Werk #19459: Fix Proxmox VE Node Info handling of missing subscription status
Thanks!
Best,
Luka
Oh well, now it crashes in a different JSON key ( max_cpu). Also the crash reports cannot be opened on my instance anymore (load screen takes forever):
        node,
    ...<6 lines>...
        data,
  File "/omd/sites/monitoring/lib/python3.13/site-packages/cmk/plugins/proxmox_ve/special_agent/agent_proxmox_ve.py", line 391, in _create_node_sections
    node_total_cpu=node["maxcpu"],
KeyError: 'maxcpu'
Failed: 'maxcpu' - please submit a crash report! (Crash-ID: eab4f7f4-496e-11f1-8000-bc2411a8ad4d)(!!)
This error comes from a feature not existing in the old 2.4 special agent.
And again it is prove why a special agent should not play around with returned data too much. It would be way easier if this special agent outputs the raw json data and let the checks then process the results.
The you have in the maximum one crashed check and not a whole special agent not working.
@martin.hirschvogel @sebkir
Hello @pep and @andreas-doehler,
I have looked at the last issue you mentioned. I am attaching an MKP that is addressing it. Can you please test it out and let me know if it works.
Thanks!
proxmox_ve_allocation-0.0.1.mkp (6.7 KB)
The problem is not such a single error but the very bad design of special agents that query JSON APIs. Until this problem is fixed these problems will come up again and again. Such a generic JSON approach would also be a good start to a generic JSON agent.
How can I verify that the MKP’s version of the special agent is used? I’ve added and enabled the extension and for good measure restarted checkmk, but checking the Proxmox host still fails with the same error:
        node,
    ...<6 lines>...
        data,
KeyError: 'maxcpu'
Failed: 'maxcpu' - please submit a crash report! (Crash-ID: ecaf5786-4c96-11f1-8000-bc2411a8ad4d)(!!)
My own Proxmox system is working also without this mkp.
System information → 3 nodes - version 9.1.9
I believe I can shed some light on the issue now: When I updated my Checkmk installation, one of node my 2-node cluster (with qdevice as the third vote) was down for RAM replacement (by the manufacturer, so about two weeks scheduled downtime).
Having just one node up was no problem with 2.4, but after I upgraded you see the issues described in this thread. After the new RAM finally arrived and the second node was up again, the special agent magically works. So the issue appears to be related to having a node down.
Hey! Thanks for the info. This makes sense. While creating the section, the special agent expected more information about the node, than it got and that caused the crash. This issue should be fixed with the MKP I sent over and I will merge the fix in the coming days.
Also, @andreas-doehler has a very good point. Right now, the special agent is doing too much data manipulation. I have planned a rework of the special agent during this development cycle and I will keep this in mind.
Again, thanks all for the feedback and pointers!
Hi everyone,
I can reproduce the exact same issue in my environment.
I have a Proxmox cluster (version 9.1.16) with two Notes and one QDevice. One Note is my main server, and the second Note is almost always turned off. Since updating to “Checkmk Community (formerly Raw) 2.5.0p2,” I can no longer use the option for special_proxmox_ve as long as one Note is turned off. The problem persists even after updating to version “Checkmk Community (formerly Raw) 2.5.0p3”.
My error message:
special_proxmox_ve]: Failed: ‘maxcpu’ - please submit a crash report! (Crash ID: 87bfb19a-547a-11f1-84fc-00e04c405b58
Is there a workaround for this problem? I hope the bug will be fixed in one of the upcoming versions, but maybe there is a way to help myself in the meantime.
Unfortunately, just letting the second node run isn’t an option for me. Electricity is simply too expensive for that in Germany.
I don’t think the MKP fixes anything. I still got the error after enabling it (as described in Agent_proxmox_ve breaks checkmk 2.5.0 when no subscription is present - #14 by pep).
It looks like that in you case the new special agent was not used. The problematic line has been changed and the logic has been changed, but your setup still fails with the old code.
The change will be available in 2.5.0p4 with werk 19461
