Hello Everyone,
we’re currently setting up checkmk (2.0.0p5 CEE on Ubuntu 18.04 LTS) and when adding our AKCP SensorProbe 2+ to the monitoring, I only get the standard checks:
While checking the integrations at the checkmk website I found some info about the support of temperature/humidity sensors of AKCP Devices:
Do I need to set up a specific rule in checkmk to make it monitor these sensors? I checked the list of service monitoring rules but couldn’t quite find something related.
The SensorProbe has SNMP enabled with default settings (SNMP v1/2, default community settings) and is already working fine with our old Icinga/Nagios checks.
If someone could enlighten me here, it would be greatly appreciated!
hi,
the checks should be found without any additional rule.
maybe this bug interferes with this: Fix cache miss on discovery
can you update your site and try if it helps?
if not could you provide a snmpwalk? i only have a different model on hand and its working fine…
Not supported is a little bit misleading.
If it works the same way as the SensorProbe 2 then it is most times only the SNMP scan function what needs a little bit tweaking.
First step to see if there are greater differences between these types is what @mace said an actual snmpwalk of the divice.
Of course checkmk supports monitoring of coffee temperature and level but it needs to be coded and implemented which is currently not the case for AKCP SP2. My colleague did that but unfortunately I am not allowed to upload the code by company policy. Need to check with my manager if we are allowed to put it on exchange.
Hi Guys,
thanks for all your messages and first of all a big Sorry for the late response.
We have updated our site and sadly it’s still the same.
I am unfamiliar with SNMP, we only have very few systems being monitored with it - all working ootb so far. So I am unsure if this snmpwalk is complete, considering the error on the second to last line. Let me know if I can improve it. snmpwalk_sp2plus.txt (3.1 KB)
The snmpwalk is only the base OIDs. For a further investigation you need to fetch the OID under iso.3.6.1.4.1.3854
If you do the snmpwalk like this snmpwalk -v2c -c public <IP> iso.3.6.1.4.1.3854 it should show some data.
The included checks cannot find anything as they check the OID iso.3.6.1.2.1.1.2.0 starts with
iso.3.6.1.4.1.3854.1 in your case it starts only with iso.3.6.1.4.1.3854
The 1 at the end is missing.
All the AKCP checks looking for data under
.1.3.6.1.4.1.3854.1.2.2
or
.1.3.6.1.4.1.3854.2.3
Is your device giving data there?
If i read the Icinga check correctly then is looking for data under .1.3.6.1.4.1.3854.3.5
That would mean some new or adopted plugins are needed.
Gerd, have you by any chance chance written this plugin for akcp plus devices ?
I was looking for this and your the only one I found who was working on it, if it is still the case ?
Hi All,
Hopping on here as we have a similar device that appears to be a rebadged version.
Similar problem, we get a basic snmp string regarding device type and uptime but not much else.
SNMP Info ServSensor2 Plus H7 1.0.5673 Oct 26 2021 05:41:14
we did, for a customer, I’m checking if we can make it public, then I’ll send it to you I’m optimistic as this really isn’t such a special check in any way. Hope to get a decision on this this week.
