For a bunch of docker containers (hosts are created by dcd using the docker hosts piggyback data) I configured the rule:
Setup > Hosts > Host monitoring rules > Host Check Command > Edit rule: Host Check Command
Always assume host to be up
But after a while the Hosts become stale.
This Werk 4428 reads as the should not happen https://checkmk.com/werk/4428
How can I fix this ?
The only thing I can think of is to set
Setup > Hosts > Host monitoring rules > Normal check interval for host checks > New rule: Normal check interval for host checks to 9999 days or something.
Any better Ideas ?
CMK version: 2.0.0p25 (CEE
OS version: Centos 7
