CMK version:
Checkmk Raw Edition 2.2.0p7
OS version:
checkmk/check-mk-raw:2.2.0-latest docker image
TASK [checkmk : Create a rule in Kubernetes rule set] ********************************************************************************************************************************
fatal: [localhost]: FAILED! => {“ansible_facts”: {“discovered_interpreter_python”: “/usr/bin/python3.8”}, “changed”: false, “id”: “”, “msg”: "Error calling API. HTTP code 400. Details: b’{"title": "Bad Request", "status": 400, "detail": "These fields have problems: conditions", "fields": {"conditions": {"host_labels": {"0": {"_schema": ["Invalid input type."]}}}}}', "}
the above message appears while trying to create rule with host_labels in Ansible.
while
host_labels": []
works fine, the above error appears with the following
- name: "Create a rule in Kubernetes rule set"
checkmk.general.rule:
server_url: "{{ server_url }}"
site: "{{ site }}"
automation_user: "{{ automation_user }}"
automation_secret: "{{ automation_secret }}"
ruleset: "special_agents:kube"
rule:
conditions: {
"host_labels": ["cmk/kubernetes/cluster:my-test-cluster2"],
properties: {
"description": "k8s cluster"
value_raw: "{'cluster-name': 'my-test-cluster2',\n 'kubernetes-api-server': {'endpoint_v2': 'https://myurl.azmk8s.io:443',\n 'verify-cert': False},\n 'monitored-objects': ['deployments',\n 'daemonsets',\n 'statefulsets',\n 'namespaces',\n 'nodes',\n 'pods',\n 'pvcs',\n 'cronjobs'],\n 'namespaces': ('namespace-include-patterns', ['custom', 'infrastructure']),\n 'token': ('password', 'XXXXXXXXXXXXXX'),\n 'usage_endpoint': ('cluster-collector',\n {'endpoint_v2': 'http://myurl.io',\n 'verify-cert': True})}"
folder: "/"
position: "top"
state: "present"
EDIT:
in GUI it should be in Kubernetes rule under host labels:
has cmk/kubernetes/cluster:my-test-cluster2
when I try to include has
"host_labels": ["has":"cmk/kubernetes/cluster:my-test-cluster2"],
it outputs
fatal: [localhost]: FAILED! => {“ansible_facts”: {“discovered_interpreter_python”: “/usr/bin/python3.8”}, “changed”: false, “id”: “”, “msg”: "Error calling API. HTTP code 400. Details: b’{"title": "Bad Request", "status": 400, "detail": "These fields have problems: conditions", "fields": {"conditions": {"host_labels": {"0": {"key": ["Missing data for required field."], "value": ["Missing data for required field."], "has": ["Unknown field."]}}}}}', "}
