Dear CheckMK Community,
I made a thread about this chain of problems here already, but I accidently marked that as solved.
To recap:
We have an APC Smart UPS and the Check APC apcupsd.conf Temperature crashes.
We have updated to 2.1.0p4 (in the last thread linked above, this is said to be the solution).
Now we get a different error message and the check still crashes.
From what I understand, this means trend computation doesn’t work anymore?
CMK version: Checkmk Enterprise Edition 2.1.0p5
OS version: Ubuntu 20.04 LTS
ValueError: Cannot compute trend. Either specify both variables 'unique_name' and 'value_store' or none.
Checkmk version 2.1.0p4
Trying to acquire lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Got lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Got lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Released lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Released lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7ff6af182850]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(pve, base_path=/omd/sites/mysite/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 68 sec, allowed is 0 sec)
Connecting via TCP to 172.16.14.30:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Write data to cache file /omd/sites/mysite/tmp/check_mk/cache/pve
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/cache/pve
Got lock on /omd/sites/mysite/tmp/check_mk/cache/pve
Releasing lock on /omd/sites/mysite/tmp/check_mk/cache/pve
Released lock on /omd/sites/mysite/tmp/check_mk/cache/pve
Closing TCP connection to 172.16.14.30:6556
[cpu_tracking] Stop [7ff6af182850 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=2.5399999991059303))]
Source: SourceType.HOST/FetcherType.PROGRAM
[cpu_tracking] Start [7ff6af17d4f0]
[ProgramFetcher] Fetch with cache settings: DefaultAgentFileCache(pve, base_path=/omd/sites/mysite/tmp/check_mk/data_source_cache/special_proxmox_ve, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 69 sec, allowed is 0 sec)
Calling: /omd/sites/mysite/share/check_mk/agents/special/agent_proxmox_ve '-u' 'checkmk@pve' '-p' 'crackundlsd' '--port' 8006 '--no-cert-check' '--timeout' 60 'pve'
Write data to cache file /omd/sites/mysite/tmp/check_mk/data_source_cache/special_proxmox_ve/pve
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/special_proxmox_ve/pve
Got lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/special_proxmox_ve/pve
Releasing lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/special_proxmox_ve/pve
Released lock on /omd/sites/mysite/tmp/check_mk/data_source_cache/special_proxmox_ve/pve
[cpu_tracking] Stop [7ff6af17d4f0 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.009999999999999981, children_user=0.67, children_system=0.11, elapsed=1.1299999989569187))]
[ ... ] removed all the piggyback stuff (hypervisor)
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/piggyback/testbuntu/pve
Got lock on /omd/sites/mysite/tmp/check_mk/piggyback/testbuntu/pve
Releasing lock on /omd/sites/mysite/tmp/check_mk/piggyback/testbuntu/pve
Released lock on /omd/sites/mysite/tmp/check_mk/piggyback/testbuntu/pve
Received piggyback data for 50 hosts
[cpu_tracking] Start [7ff6af1102b0]
value store: synchronizing
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/counters/pve
Got lock on /omd/sites/mysite/tmp/check_mk/counters/pve
Releasing lock on /omd/sites/mysite/tmp/check_mk/counters/pve
Released lock on /omd/sites/mysite/tmp/check_mk/counters/pve
APC apcupsd.conf Status UPSNAME: pve, MODEL: Smart-UPS 1500 RM, SERIALNO: AS0638331142, FIRMWARE: 617.3.I USB FW:8.1, UPSMODE: Stand Alone, Output Voltage: 232V, Output Load: 19.50%, Battery Capacity: 100.00%, Time Left: 1 hour 4 minutes
[cpu_tracking] Stop [7ff6af1102b0 - Snapshot(process=posix.times_result(user=0.009999999999999787, system=0.009999999999999953, children_user=0.0, children_system=0.0, elapsed=0.019999999552965164))]
Trying to acquire lock on /omd/sites/mysite/var/check_mk/crashes/base/403483a0-fc4a-11ec-84c9-9d78292c7bf1/crash.info
Got lock on /omd/sites/mysite/var/check_mk/crashes/base/403483a0-fc4a-11ec-84c9-9d78292c7bf1/crash.info
Releasing lock on /omd/sites/mysite/var/check_mk/crashes/base/403483a0-fc4a-11ec-84c9-9d78292c7bf1/crash.info
Released lock on /omd/sites/mysite/var/check_mk/crashes/base/403483a0-fc4a-11ec-84c9-9d78292c7bf1/crash.info
File "/omd/sites/mysite/bin/cmk", line 98, in <module>
exit_status = modes.call("--check", None, opts, args)
File "/omd/sites/mysite/lib/python3/cmk/base/modes/__init__.py", line 69, in call
return handler(*handler_args)
File "/omd/sites/mysite/lib/python3/cmk/base/modes/check_mk.py", line 1804, in mode_check
checking.commandline_checking(
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/decorator.py", line 43, in wrapped_check_func
status, output_text = _combine_texts(check_func(hostname, *args, **kwargs))
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 121, in commandline_checking
return _execute_checkmk_checks(
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 174, in _execute_checkmk_checks
num_success, plugins_missing_data = check_host_services(
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 322, in check_host_services
success = _execute_check(
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 382, in _execute_check
submittable = get_aggregated_result(
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 470, in get_aggregated_result
result = _aggregate_results(
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 578, in _aggregate_results
perfdata, results = _consume_and_dispatch_result_types(subresults)
File "/omd/sites/mysite/lib/python3/cmk/base/agent_based/checking/__init__.py", line 622, in _consume_and_dispatch_result_types
for subr in subresults:
File "/omd/sites/mysite/lib/python3/cmk/base/api/agent_based/register/check_plugins.py", line 94, in filtered_generator
for element in generator(*args, **kwargs):
File "/omd/sites/mysite/local/lib/python3/cmk/base/plugins/agent_based/apcaccess.py", line 163, in check_apcaccess_temp
yield from temperature.check_temperature(float(itemp[0]),
File "/omd/sites/mysite/lib/python3/cmk/base/plugins/agent_based/utils/temperature.py", line 302, in check_temperature
raise ValueError(
Maybe someone can shed some light on this for me, thanks in advanced!
Best regards,
pixelpoint
