Apt plugin not working on some hosts
CMK version:
CRE 2.1.0p9
OS version:
Ubuntu 18.04.6 LTS
[agent] Success, Missing monitoring data for plugins: aptWARN, execution time 0.8 sec
Output of “cmk --debug -vvn serverxyz.domain.de”:
Checkmk version 2.1.0p9
Trying to acquire lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Got lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Trying to acquire lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Got lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Released lock on /omd/sites/mysite/var/check_mk/license_usage/history.json
Releasing lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
Released lock on /omd/sites/mysite/var/check_mk/license_usage/next_run
+ FETCHING DATA
[cpu_tracking] Start [7fbbcfdf4a30]
[TCPFetcher] Fetch with cache settings: DefaultAgentFileCache(serverxyz.domain.de, base_path=/omd/sites/mysite/tmp/check_mk/cache, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=False, use_outdated=False, simulation=False)
Not using cache (Too old. Age is 25 sec, allowed is 0 sec)
Connecting via TCP to IP:6556 (5.0s timeout)
Detected transport protocol: TransportProtocol.TLS (b'16')
Write data to cache file /omd/sites/mysite/tmp/check_mk/cache/serverxyz.domain.de
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/cache/serverxyz.domain.de
Got lock on /omd/sites/mysite/tmp/check_mk/cache/serverxyz.domain.de
Releasing lock on /omd/sites/mysite/tmp/check_mk/cache/serverxyz.domain.de
Released lock on /omd/sites/mysite/tmp/check_mk/cache/serverxyz.domain.de
Closing TCP connection to IP:6556
[cpu_tracking] Stop [7fbbcfdf4a30 - Snapshot(process=posix.times_result(user=0.010000000000000009, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.75))]
[cpu_tracking] Start [7fbbcfdf4790]
[PiggybackFetcher] Fetch with cache settings: NoCache(serverxyz.domain.de, base_path=/omd/sites/mysite/tmp/check_mk/data_source_cache/piggyback, max_age=MaxAge(checking=0, discovery=120, inventory=120), disabled=True, use_outdated=False, simulation=False)
No piggyback files for 'serverxyz.domain.de'. Skip processing.
No piggyback files for 'IP'. Skip processing.
[cpu_tracking] Stop [7fbbcfdf4790 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
<<<df>>> / Transition HostSectionParser -> HostSectionParser
<<<apt:cached(1672730682,3600):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
No persisted sections
  -> Add sections: ['apt', 'check_mk', 'checkmk_agent_plugins_lnx', 'cifsmounts', 'cmk_agent_ctl_status', 'cpu', 'df', 'diskstat', 'job', 'kernel', 'labels', 'lnx_if', 'local', 'md', 'mem', 'mounts', 'nfsmounts', 'ps_lnx', 'systemd_units', 'tcp_conn_stats', 'uptime', 'vbox_guest']
  -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7fbbcff56640]
value store: synchronizing
Trying to acquire lock on /omd/sites/mysite/tmp/check_mk/counters/serverxyz.domain.de
Got lock on /omd/sites/mysite/tmp/check_mk/counters/serverxyz.domain.de
Releasing lock on /omd/sites/mysite/tmp/check_mk/counters/serverxyz.domain.de
Released lock on /omd/sites/mysite/tmp/check_mk/counters/serverxyz.domain.de
APT Updates          PEND - Check plugin received no monitoring data
[cpu_tracking] Stop [7fbbcff56640 - Snapshot(process=posix.times_result(user=0.16999999999999993, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.17999999970197678))]
[agent] Success, Got no information from host(!!), execution time 0.9 sec | execution_time=0.930 user_time=0.180 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.740
Additional Information
The “CheckMK”-service successfully detects the existence of a plugin on my hosts.
I can run /usr/lib/check_mk_agent/plugins/3600/mk_apt with correct output.
Output of cmk --debug -vvv --detect-plugins mk_apt serverxyz.domain.de:
OMD[mysite]:~$  cmk --debug -vvv --detect-plugins mk_apt serverxyz.domain.de
+ FETCHING DATA
[cpu_tracking] Start [7f804478af10]
Not using cache (Mode Mode.FORCE_SECTIONS)
[cpu_tracking] Stop [7f804478af10 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.7399999983608723))]
[cpu_tracking] Start [7f804478ad60]
[cpu_tracking] Stop [7f804478ad60 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
<<<apt:cached(1672734289,3600):sep(0)>>> / Transition HostSectionParser -> HostSectionParser
  -> Add sections: []
  -> Add sections: []
[cpu_tracking] Start [7f8044a30400]
value store: already loaded
[cpu_tracking] Stop [7f8044a30400 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.009999997913837433))]
[agent] Success, execution time 0.7 sec | execution_time=0.750 user_time=0.000 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_agent=0.740
I appreciate every help. Let me know if there are other information needed.
  • Julian
Hi Julian,
does the plugin work directly executed on the client?
/usr/lib/check_mk_agent/plugins/mk_apt
And maybe remove the cache in /var/lib/check_mk_agent/cache/* if it seems ok. After that your could run the cmk .. again. Or just run check_mk_agent on the host if it is not “encrypted”.
it works when i execute it on the client. removed the cache and it still works.
after i did cmk --debug -vvn serverxyz.domain.de again, i can see this (because i enforce the apt-service for testing purposes):
CPU load             15 min load: 0.04, 15 min load per core: 0.02 (2 cores)
Check_MK Agent       Version: 2.1.0p9, OS: linux, Agent plugins: 1, Local checks: 0
Filesystem /         27.78% used (16.06 of 57.79 GB), trend: +77.61 kB / 24 hours
Interface ens160     [2], (up), MAC: [...], Speed: 10 GBit/s, In: 14.7 kB/s (<0.01%), Out: 3.80 kB/s (<0.01%)
Memory               Total virtual memory: 47.2% - 1.37 GB of 2.90 GB, 9 additional details available
Uptime               Up since Jan 02 2023 14:14:28, Uptime: 1 day 0 hours
The PEND won’t resolve in OK or WARN.
There has been an update to the mk_apt checkplugin in Checkmk 2.1.0p14 to support the new behaviour on Ubuntu Linux. So ensure to update both the Checkmk server and the mk_apt agent plugin to 2.1.0p14 or higher.
Thank you. I will give feedback when i had a chance to update my instance.
Updated my site to the latest version 2.1.0p18. Updated every Linux Host to the new agent, placed the apt-plugin in the correct path, checked the permissions.
Rescheduled the CheckMK Service at each host, new agent version is detected and the autodiscovery of the APT-Service works like a charm.
Thank you!
