Aruba AccessPoints that fall under VirtualControler are not visible in CheckMK
CMK version:
Appliance 2.2.0p14.cee
Checkmk version 2.2.0p14
+ FETCHING DATA
Source: SourceInfo(hostname='GWE-VC.XXX.XXXX.nl', ipaddress='XX.XX.XX.247', ident='snmp', fetcher_type=<FetcherType.SNMP: 7>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f37afffb650]
Read from cache: SNMPFileCache(GWE-VC.XXX.XXXX.nl, path_template=/omd/sites/si/tmp/check_mk/data_source_cache/snmp/{mode}/{hostname}, max_age=MaxAge(checking=0, discovery=90.0, inventory=90.0), simulation=False, use_only_cache=False, file_cache_mode=6)
Not using cache (Too old. Age is 44 sec, allowed is 0 sec)
SNMP scan:
Getting OID .1.3.6.1.2.1.1.1.0: Executing SNMP _Mode.GET of .1.3.6.1.2.1.1.1.0 on GWE-VC.XXX.XXXX.nl
=> [b'ArubaOS (MODEL: 575), Version 8.XXX LSR'] OCTETSTR
Getting OID .1.3.6.1.2.1.1.2.0: Executing SNMP _Mode.GET of .1.3.6.1.2.1.1.2.0 on GWE-VC.XXX.XXXX.nl
=> [b'.1.3.6.1.4.1.14823.1.2.71'] OBJECTID
Using cached OID .1.3.6.1.2.1.1.1.0: 'ArubaOS (MODEL: 575), Version 8.XXX LSR'
SNMP scan found snmp_uptime
Trying to acquire lock on /omd/sites/si/tmp/check_mk/snmp_scan_cache/GWE-VC.XXX.XXXX.nl.XX.XX.XX.247
Got lock on /omd/sites/si/tmp/check_mk/snmp_scan_cache/GWE-VC.XXX.XXXX.nl.XX.XX.XX.247
Releasing lock on /omd/sites/si/tmp/check_mk/snmp_scan_cache/GWE-VC.XXX.XXXX.nl.XX.XX.XX.247
Released lock on /omd/sites/si/tmp/check_mk/snmp_scan_cache/GWE-VC.XXX.XXXX.nl.XX.XX.XX.247
if64: Fetching data (SNMP walk cache is enabled: Use any locally cached information)
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.1" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.1.1 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.2 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.50 => [b'50'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.51 => [b'51'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.52 => [b'52'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.70 => [b'70'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.71 => [b'71'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.72 => [b'72'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.90 => [b'90'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.91 => [b'91'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.92 => [b'92'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.93 => [b'93'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.94 => [b'94'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.499 => [b'499'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.1.500 => [b'500'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.2" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.2.1 => [b'eth0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.2 => [b'eth1'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.50 => [b'radio0_ssid_id0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.51 => [b'radio0_ssid_id1'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.52 => [b'radio0_ssid_id2'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.70 => [b'radio1_ssid_id0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.71 => [b'radio1_ssid_id1'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.72 => [b'radio1_ssid_id2'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.90 => [b'gre0'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.91 => [b'gre1'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.92 => [b'gre2'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.93 => [b'gre3'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.94 => [b'gre4'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.499 => [b'VC'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.2.500 => [b'BR0'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.3" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.3.1 => [b'62'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.2 => [b'62'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.50 => [b'188'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.51 => [b'188'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.52 => [b'188'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.70 => [b'188'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.71 => [b'188'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.72 => [b'188'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.90 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.91 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.92 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.93 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.94 => [b'131'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.499 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.3.500 => [b'1'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.5" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.5.1 => [b'1000000000'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.50 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.51 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.52 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.70 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.71 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.72 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.90 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.91 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.92 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.93 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.94 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.499 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.2.2.1.5.500 => [b'0'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.8" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.8.1 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.2 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.50 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.51 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.52 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.70 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.71 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.72 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.90 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.91 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.92 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.93 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.94 => [b'2'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.499 => [b'1'] 'INTEGER'
.1.3.6.1.2.1.2.2.1.8.500 => [b'1'] 'INTEGER'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.6" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.6.1 => [b'52962363950'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.50 => [b'7798383'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.51 => [b'120'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.52 => [b'545845420'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.70 => [b'28543151'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.71 => [b'510'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.72 => [b'298251324'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.6.500 => [b'5611477'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.7" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.7.1 => [b'98853212'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.50 => [b'99193'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.51 => [b'4'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.52 => [b'5434562'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.70 => [b'453893'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.71 => [b'17'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.72 => [b'2740957'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.7.500 => [b'50591'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.8" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.8.1 => [b'7836600'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.50 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.51 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.52 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.70 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.71 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.72 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.8.500 => [b'0'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.9" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.9.1 => [b'7836600'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.50 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.51 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.52 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.70 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.71 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.72 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.9.500 => [b'0'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.13" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.13.1 => [b'43'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.50 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.51 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.52 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.70 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.71 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.72 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.90 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.91 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.92 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.93 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.94 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.499 => [b'1920819'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.13.500 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.14" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.14.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.50 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.51 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.52 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.70 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.71 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.72 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.90 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.91 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.92 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.93 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.94 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.499 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.14.500 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.10" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.10.1 => [b'13035854332'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.50 => [b'316193120'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.51 => [b'434408172'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.52 => [b'7025025412'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.70 => [b'709971033'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.71 => [b'886524090'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.72 => [b'3933627789'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.10.500 => [b'14090454'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.11" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.11.1 => [b'40521289'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.50 => [b'1258099'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.51 => [b'1224639'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.52 => [b'12310006'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.70 => [b'2961680'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.71 => [b'2869010'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.72 => [b'8834958'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.11.500 => [b'42760'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.12" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.12.1 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.50 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.51 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.52 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.70 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.71 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.72 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.12.500 => [b'0'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.13" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.13.1 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.2 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.50 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.51 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.52 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.70 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.71 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.72 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.90 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.91 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.92 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.93 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.94 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.499 => [b'0'] 'COUNTER64'
.1.3.6.1.2.1.31.1.1.1.13.500 => [b'0'] 'COUNTER64'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.19" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.19.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.50 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.51 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.52 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.70 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.71 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.72 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.90 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.91 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.92 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.93 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.94 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.499 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.19.500 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.20" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.20.1 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.2 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.50 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.51 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.52 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.70 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.71 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.72 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.90 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.91 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.92 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.93 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.94 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.499 => [b'0'] 'COUNTER'
.1.3.6.1.2.1.2.2.1.20.500 => [b'0'] 'COUNTER'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.21" on GWE-VC.XXX.XXXX.nl
Executing SNMP _Mode.GET of .1.3.6.1.2.1.2.2.1.21 on GWE-VC.XXX.XXXX.nl
=> [None] NOSUCHOBJECT
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.18" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.18.1 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.2 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.50 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.51 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.52 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.70 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.71 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.72 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.90 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.91 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.92 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.93 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.94 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.499 => [b''] 'OCTETSTR'
.1.3.6.1.2.1.31.1.1.1.18.500 => [b''] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.2.2.1.6" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.2.2.1.6.1 => [b'H/k\xc1\x1aX'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.2 => [b'H/k\xc1\x1aY'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.50 => [b'H/k\x91\xa5\x90'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.51 => [b'H/k\x91\xa5\x91'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.52 => [b'H/k\x91\xa5\x92'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.70 => [b'H/k\x91\xa5\x80'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.71 => [b'H/k\x91\xa5\x81'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.72 => [b'H/k\x91\xa5\x82'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.90 => [b'\x00\x00\x00\x00\x00\x00'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.91 => [b'\x00\x00\x00\x00\x00\x00'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.92 => [b'\x00\x00\x00\x00\x00\x00'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.93 => [b'\x00\x00\x00\x00\x00\x00'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.94 => [b'\x00\x00\x00\x00\x00\x00'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.499 => [b'H/k\xc1\x1aX'] 'OCTETSTR'
.1.3.6.1.2.1.2.2.1.6.500 => [b'H/k\xc1\x1aX'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.31.1.1.1.15" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.31.1.1.1.15.1 => [b'1000'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.2 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.50 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.51 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.52 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.70 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.71 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.72 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.90 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.91 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.92 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.93 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.94 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.499 => [b'0'] 'GAUGE'
.1.3.6.1.2.1.31.1.1.1.15.500 => [b'0'] 'GAUGE'
Executing BULKWALK of ".1.3.6.1.2.1.1.1" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.1.1.0 => [b'ArubaOS (MODEL: 575), Version 8.XXX LSR'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.2" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.1.2.0 => [b'.1.3.6.1.4.1.14823.1.2.71'] 'OBJECTID'
Executing BULKWALK of ".1.3.6.1.2.1.1.4" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.1.4.0 => [b''] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.5" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.1.5.0 => [b'AP-GWE-15'] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.6" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.1.6.0 => [b''] 'OCTETSTR'
Executing BULKWALK of ".1.3.6.1.2.1.1.3" on GWE-VC.XXX.XXXX.nl
.1.3.6.1.2.1.1.3.0 => [b'815937124'] 'TICKS'
Executing BULKWALK of ".1.3.6.1.2.1.25.1.1" on GWE-VC.XXX.XXXX.nl
Executing SNMP _Mode.GET of .1.3.6.1.2.1.25.1.1 on GWE-VC.XXX.XXXX.nl
Write data to cache file /omd/sites/si/tmp/check_mk/data_source_cache/snmp/checking/GWE-VC.XXX.XXXX.nl
Trying to acquire lock on /omd/sites/si/tmp/check_mk/data_source_cache/snmp/checking/GWE-VC.XXX.XXXX.nl
Got lock on /omd/sites/si/tmp/check_mk/data_source_cache/snmp/checking/GWE-VC.XXX.XXXX.nl
Releasing lock on /omd/sites/si/tmp/check_mk/data_source_cache/snmp/checking/GWE-VC.XXX.XXXX.nl
Released lock on /omd/sites/si/tmp/check_mk/data_source_cache/snmp/checking/GWE-VC.XXX.XXXX.nl
[cpu_tracking] Stop [7f37afffb650 - Snapshot(process=posix.times_result(user=0.020000000000000018, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.2199999988079071))]
Source: SourceInfo(hostname='GWE-VC.XXX.XXXX.nl', ipaddress='XX.XX.XX.247', ident='piggyback', fetcher_type=<FetcherType.PIGGYBACK: 4>, source_type=<SourceType.HOST: 1>)
[cpu_tracking] Start [7f37b0000490]
Read from cache: NoCache(GWE-VC.XXX.XXXX.nl, path_template=/dev/null, max_age=MaxAge(checking=0.0, discovery=0.0, inventory=0.0), simulation=False, use_only_cache=False, file_cache_mode=1)
No piggyback files for 'GWE-VC.XXX.XXXX.nl'. Skip processing.
No piggyback files for 'XX.XX.XX.247'. Skip processing.
[cpu_tracking] Stop [7f37b0000490 - Snapshot(process=posix.times_result(user=0.0, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.0))]
+ PARSE FETCHER RESULTS
HostKey(hostname='GWE-VC.XXX.XXXX.nl', source_type=<SourceType.HOST: 1>) -> Add sections: ['if64', 'snmp_info', 'snmp_uptime']
HostKey(hostname='GWE-VC.XXX.XXXX.nl', source_type=<SourceType.HOST: 1>) -> Add sections: []
Received no piggyback data
[cpu_tracking] Start [7f37affee7d0]
value store: synchronizing
Trying to acquire lock on /omd/sites/si/tmp/check_mk/counters/GWE-VC.XXX.XXXX.nl
Got lock on /omd/sites/si/tmp/check_mk/counters/GWE-VC.XXX.XXXX.nl
Releasing lock on /omd/sites/si/tmp/check_mk/counters/GWE-VC.XXX.XXXX.nl
Released lock on /omd/sites/si/tmp/check_mk/counters/GWE-VC.XXX.XXXX.nl
Interface BR0 [500], (up), MAC: XX:XX:XX:XX:XX:58, Speed: unknown, In: 0.00 B/s, Out: 0.00 B/s
Interface VC [499], (up), MAC: XX:XX:XX:XX:XX:58, Speed: unknown, In: 0.00 B/s, Out: 0.00 B/s
Interface eth0 [1], (up), MAC: XX:XX:XX:XX:XX:58, Speed: 1 GBit/s, In: 10.0 kB/s (<0.01%), Out: 4.21 kB/s (<0.01%)
Interface eth1 [2], (down), MAC: XX:XX:XX:XX:XX:59, Speed: unknown
Interface gre0 [90], (down), MAC: 00:00:00:00:00:00, Speed: unknown
Interface gre1 [91], (down), MAC: 00:00:00:00:00:00, Speed: unknown
Interface gre2 [92], (down), MAC: 00:00:00:00:00:00, Speed: unknown
Interface gre3 [93], (down), MAC: 00:00:00:00:00:00, Speed: unknown
Interface gre4 [94], (down), MAC: 00:00:00:00:00:00, Speed: unknown
Interface radio0_ssid_id0 [50], (up), MAC: XX:XX:XX:XX:XX:90, Speed: unknown, In: 0.00 B/s, Out: 11.2 B/s
Interface radio0_ssid_id1 [51], (up), MAC: XX:XX:XX:XX:XX:91, Speed: unknown, In: 0.00 B/s, Out: 16.0 B/s
Interface radio0_ssid_id2 [52], (up), MAC: XX:XX:XX:XX:XX:92, Speed: unknown, In: 40.8 B/s, Out: 175 B/s
Interface radio1_ssid_id0 [70], (up), MAC: XX:XX:XX:XX:XX:80, Speed: unknown, In: 1.49 B/s, Out: 39.6 B/s
Interface radio1_ssid_id1 [71], (up), MAC: XX:XX:XX:XX:XX:81, Speed: unknown, In: 0.00 B/s, Out: 48.7 B/s
Interface radio1_ssid_id2 [72], (up), MAC: XX:XX:XX:XX:XX:82, Speed: unknown, In: 0.00 B/s, Out: 72.6 B/s
SNMP Info ArubaOS (MODEL: 575), Version 8.XXX LSR, AP-GWE-15, ,
Uptime Up since Oct 10 2023 00:13:30, Uptime: 94 days 10 hours
[cpu_tracking] Stop [7f37affee7d0 - Snapshot(process=posix.times_result(user=0.06000000000000005, system=0.0, children_user=0.0, children_system=0.0, elapsed=0.06000000238418579))]
[snmp] Success, [piggyback] Success (but no data found for this host), execution time 0.3 sec | execution_time=0.280 user_time=0.080 system_time=0.000 children_user_time=0.000 children_system_time=0.000 cmk_time_snmp=0.200 cmk_time_agent=0.000
Description of problem
We use Aruba AirWave with several AccessPoints underneath as a Virtual Controller.
There are x number of AccessPoints underneath the VirtualController.
We added the VirtualControllers to CheckMK (2.2.0p14.cee) via SNMP and added a Rule as described in:
However, we do not see any information from the AccessPoints that fall under the VirtualController.
I performed an SNMP Walk from the CheckMK GUI (Monitoring via SNMP - Monitoring of SNMP devices with Checkmk) and downloaded the text file.
I see the AccessPoints in there aiAPName .1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2 under .1.3.6.1.4.1.14823.2.3.3.1.2.1 (https://mibs.observium.org/mib/AI-AP-MIB/#aiAccessPointTable) that fall under the Virtual Controller:
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.168.254 AP-GWE-08
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.169.192 AP-GWE-07
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.171.156 AP-GWE-11
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.188.22 AP-GWE-13
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.193.146 AP-GWE-14
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.195.100 AP-GWE-12
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.202.216 AP-GWE-01
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.203.244 AP-GWE-09
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.216.134 AP-GWE-05
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.217.200 AP-GWE-04
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.224.236 AP-GWE-10
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.227.50 AP-GWE-06
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.68.18.68.196.228.62 AP-GWE-02
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.72.47.107.193.26.88 AP-GWE-15
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.168.91.247.206.166.60 AP-GWE-17
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.168.91.247.206.172.232 AP-GWE-03
.1.3.6.1.4.1.14823.2.3.3.1.2.1.1.2.204.136.199.207.163.214 AP-GWE-16
The information is there, but it is not visible in CheckMK.
I expected that “aruba_wlc_aps” plugin (aruba_wlc_aps: new inventory plugin for Aruba Networks WLAN Controller which displays name, group name, model, serial number and system location of all access points of this WLC) would be used.
Under SNMP info I only see the AccessPoint name that the VC role has.
Am I missing something or making a mistake?
