Authentication for HW/SW inventory web api
my goal is to get host inventory data with HTTP API (cmk version 2.1).
I can successfully use the REST API with an authorization header as described in the docs:
curl --header “Authorization: Bearer automationuser password” “https://myserver/mysite/check_mk/api/1.0/objects/host_config/myhost
But this doesn’t work with the HW/SW inventory API. I get no output:
curl --header “Authorization: Bearer automationuser password” “https://myserver/mysite/check_mk/host_inv_api.py?host=myhost&output_format=json
I can access the HW/SW inventory API by adding _username and _secret parameters to the URL but this is not recommended because it’s logged by Apache.
How can I access the HW/SW inventory API using an authorization header?
In the REST API documentation I read about the column “host_mk_inventory” of hosts table. How does an URL have to look like to query that data?
Thanks in advance for your support.
Hello Eric1. Please check here how to call data from Inventory API:
Implemented API for exporting the full host inventory
You can also Query for specific data from this API using for example: http://mmwcheckmk/cmk_test/check_mk/host_inv_api.py?host=linux-for-alex&request={“paths”:[“software.packages.”]}&output_format=json
Not sure if it is planned to add Inventory Data to the RestAPI…but there is a feature request to upvote available: https://ideas.checkmk.com/suggestions/319204/add-hwsw-inventory-data-to-the-rest-api
Unfortunately the “Werk #3585” doesn’t mention user authentication. Does authorization with http header work with this api?
You don’t have to use GET for this, you can add the username/secret to a POST entry instead, that way it won’t show in the access logs…
Thanks for that hint. I’m using a POST request now.
My working POST request using python requests:
r = requests.post(‘https://myserver/mysite/check_mk/host_inv_api.py’, headers = {‘Accept’: ‘application/json’}, data = {‘_username’: ‘abc’, ‘_secret’: passwd, ‘request’: ‘{“hosts”:[’ + hostlist + ‘]}’, ‘output_format’: ‘json’})
