Azure Advisor - EDR configuration issues should be resolved on virtual machines
I am running the pre-configured Linux Azure VM for CheckMK from the Azure Marketplace. Under Azure Advisor security recommendations, I am seeing two findings for the CheckMK VM.
1 - Anti-virus is off or partially configured
2 - Both full and quick scans are out of 7 days
Since this is a pre-configured VM from the marketplace, I was unsure if there was a Defender plugin to use on a Linux VM. If it does exist, can I get a link for documentation on how to implement?
If it does not exist, I can exempt the recommendation from future Advisor scans.
